20 Most Recent
Ubi Soft Catz 5 (Windows) (680901) for PC Questions & Answers
Stuck Pregnancy
Hi Amanda,I did some research as well. Apparently the game counts days not only using the time/date on your computer, but also only when you close down and restart the program. For example, if you leave the game on for two days, the game thinks it is that same day. I would try to close the game down completely and then reopen it. Hopefully that will put the kittens in your nursery.
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
My suitcase on petz5 wont let me put a bubble
Okay, get out another bubble blowing box, and then put the first bubble blower in the box with the second one. You can put two in one box and put them away together. Hope this helped!
The Catz pet graphics are horribe - there're two views - one is rounded-soft looing, the other (interactive one) is all angles, etc. The rest of the items view fine.
Test all leads that attach to your hard drive including electrical extensions EIDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
computers need power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settingsalways click APPLY after making any changes
hope this helps
All of the toys/food aren't there after i have
REASONS I HATE THIS GAME
- every time i try to go into a room with a mini game in it i get like 50,000,000 messages saying to play a mini game click on mr bones or the vase or whater i have to click on.why is it doing that?
- i have the two love poshons and its been three years and they wont have babies
- my computer dies everytime i try to use this game
- the screen gos all blury and i cant see my opets
- when i tried to return it the people said u open it u cant return it
- THIS IS THE STUPIDST THING EVER LOOK HOW MANY PROBLEMS ITS GIVING ME
For petz 5, i just
Your resolution is too high. Reduce it to 1024x768 and they will appear normal.
I can't uninstall it at
Install a software REVO uninstaller from www.filehippo.com. And you can uninstall any software from the computer using that no matter what the software is.
Thanks
If this was helpful, then kindly rate me.
