20 Most Recent Zanussi ZWF1440 Front Load Washer Questions & Answers
Error code e71
Blocked filter or faulty pump
1/10/2018 4:57:40 PM • Zanussi ZWF1440... • Answered on Jan 10, 2018
Showing error 23
E23 - Drain pump triac faulty Could be: Drain pump faulty; wiring faulty; PCB faulty. Dado
7/6/2016 8:22:36 PM • Zanussi ZWF1440... • Answered on Jul 06, 2016
E23 error ? what is it
7/6/2016 8:20:11 PM • Zanussi ZWF1440... • Answered on Jul 06, 2016
3answers
My AEG Lavamat shows the
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again
when you obtain your error code message me back with what numbers your machine is showing and I will diagnose your error code for you. I await your reply Thanks
Rick
8/21/2015 11:44:35 AM • Zanussi ZWF1440... • Answered on Aug 21, 2015
0answers
0answers
No error code showing
It may be the child safety lock. There are often two buttons on the control panel which have to be pressed simultaneously (and held in) and they turn the lock off. The buttons should have a tiny picture of a lock underneath them.
2/19/2014 3:48:18 PM • Zanussi ZWF1440... • Answered on Feb 19, 2014
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
12/25/2013 8:39:19 PM • Zanussi ZWF1440... • Answered on Dec 25, 2013
0answers
3answers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
1/8/2013 11:09:25 PM • Zanussi ZWF1440... • Answered on Jan 08, 2013
Zanussi ZWF1440 Front Load Washer Logo
144 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
aeg lavamat shows
  • Washing Machines
