20 Most Recent Zanussi ZWF1420W Front Load Washer Questions & Answers
0answers
I have a Zanussi zwf1621s washing machine which is approx 6 yrs old. When spinning today it made a strange noise so i turned the machine off. When I went to restart the machine all the lights came on
it really depends on the sound it made, if it was a rumble or a screech it could be the motor, or grinding it could be the bearing or something is in the drum, if it was on a drain cycle it could be the pump or something in the pump blocking/catching on the fins in the pump ( hair can affect the pump). coins can sometimes get to the drum housing and cause damage, ie catch the heating element, this can make the washer not start as the washer has a earthing sensor on the element resistance. hope this helps.
11/6/2017 4:21:45 AM • Zanussi ZWF1420W... • Answered on Nov 06, 2017
Drum paddles falling off
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
5/5/2017 10:00:15 PM • Zanussi ZWF1420W... • Answered on May 05, 2017
0answers
0answers
Aquacycle
Be the first to answer 6/13/2013 2:14:06 PM • Zanussi ZWF1420W... • Posted on Jun 13, 2013Be the first to answer
0answers
Zanussi fj12544 fills but won't wash
see this probably cause:t doesn't pump or spinfrozen pulley or broken belt, replace It pumps, but doesn't spinlid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective. It spins only with the lid closedlid swtich defective. 6_19_2012_1_11_58_am.gif
6/19/2012 1:12:12 AM • Zanussi ZWF1420W... • Answered on Jun 19, 2012
LED lights flashing
maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .home led lights
5/23/2012 10:29:20 AM • Zanussi ZWF1420W... • Answered on May 23, 2012
How do i fit a door seal on a zanussi 1421W
I shall give you a video of a Bosch from which you can gain a lot of knowledge on how to replace the gasket.
http://www.espares.co.uk/advice/washing-machines/a/7/1394/how-to-replace-the-door-seal-on-a-washing-mac.html
7/18/2011 9:28:53 AM • Zanussi ZWF1420W... • Answered on Jul 18, 2011
Any advice on how to
the door seal or do you mean the rubber boot that goes from outter tub to the outer frame simply seat the seal all the way around into the groved slot on the rubber boot and then attach the top of the retaining ring first and slide the left side on while holding the corner of the right side move your screwdriver from the top left furthest point in a couter clockwise direction until the metal retaining ring is half seated you can see down the bottom there is a small spring that allows the tension on the other side you would hold with a finger the last point that you seated the retaining ring and start on the top right side with your flat screwdriver and work your way clock wise until you came to the are with the spring then just put your screwdriver in the area where the spring is located and pry towards you walla this piece is also called door bellows to others as well it is termed as a rubber boot where I am currently if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s tomatoes dont grow particulary well with washer machine on top on the other hand a type of berry would have no problem at all :)
4/10/2011 11:42:31 AM • Zanussi ZWF1420W... • Answered on Apr 10, 2011
Zanussi ZWF1420W Front Load Washer Logo
73 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
any advice
  • Washing Machines
