20 Most Recent Zanussi F1045W Front Load Washer Questions & Answers
My zanussi aquacycle 1000. Programme knob is just cycling through the was cycle really quckly without the machine washing, the drum is moving slightly back and forth and sounds like its trying to enga
Could be that the drive pulley behind the drum has loosened on the shaft. You do not say that you can hear the motor, but the drum moves slightly. Some machines have a shear pin which fails to prevent damage to the drum and motor. If you machine has one of these, it will be obvious when you get the back off. The lack of load on the motor could do strange things to the programmer. Good luck.
2/3/2018 7:47:54 PM • Zanussi F1045W... • Answered on Feb 03, 2018
Hello, I have a beko wm5100w and it seems to be
It could be a faulty thermistor (showing high temperature) or water sensor fault that is causing the pump to run. Just try and unplug it for 3-4 hours, and see if it resets itself, if not replace sensors, and if that does not work, replace the main board. Here is the manual: http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21 This is the actual reset/diagnostic mode https://www.youtube.com/watch?v=8C4J3leArY0 https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
9/10/2017 3:06:20 PM • Zanussi F1045W... • Answered on Sep 10, 2017
How do I fix the lock
You're going to need to open the washer and retrieve that lock, Malin. You should also get a replacement for it and install it so the washer will lock properly again. Last, tell your sister not to be so brutal with equipment - that never helps anything.
7/29/2014 12:58:16 PM • Zanussi F1045W... • Answered on Jul 29, 2014
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies... Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
4/11/2014 3:30:54 AM • Zanussi F1045W... • Answered on Apr 11, 2014
0answers
Zanussi 1200 essential washing machine, cleaned out filter now will not fill with water
Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
2/8/2014 2:19:48 PM • Zanussi F1045W... • Answered on Feb 08, 2014
0answers
Drum will not turn.
Sounds like you've got something stuck in between the drum and tub the best way to check is through the heater at the rear of the machine. Could also be the motor or drum bearings have seized if its the drum bearings there's usually brown oil coming from the back of the drum. Take the belt off to see if either the drum or motor can be turned manualy. hope this helps.
3/26/2013 7:29:36 PM • Zanussi F1045W... • Answered on Mar 26, 2013
Zwf16581w water not draining, filter is clean, please help
Check the drain lines for blockage.
11/22/2012 10:02:18 AM • Zanussi F1045W... • Answered on Nov 22, 2012
Conditioner not going down
See previous answer
5/19/2012 8:58:07 PM • Zanussi F1045W... • Answered on May 19, 2012
Zanussi F1045W Front Load Washer Logo
116 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
zwf16581w water not draining filter
  • Washing Machines
