20 Most Recent Zanussi 3.46 cu. ft. / 98 liter Upright Freezer ZF56SI Questions & Answers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
10/3/2019 10:07:47 PM • Zanussi 3.46 cu.... • Answered on Oct 03, 2019
What is the red warning light telling me
Higher than normal temperature. Is your ice cream soft?
1/28/2011 2:09:06 PM • Zanussi 3.46 cu.... • Answered on Jan 28, 2011
2answers
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring). Dado
12/21/2016 8:33:13 PM • Zanussi Freezers • Answered on Dec 21, 2016
How to add refridgerant gas to an lg fridge freezer
For such a procedure you should have knowledge and a lot of expensive work condition like: - Vacuum pump - Charging station - Manifolds - Recovery station - Electronic charging scale - Electronic leak detector or UV leak detector and so on ...... The situation is further complicated by some of the new environmental gases which are explosive so you need to be qualified and trained person. It is best to leave that to the specialist or qualified service personnel. Dado
1/16/2015 7:43:04 PM • Zanussi Freezers • Answered on Jan 16, 2015
Zanussi freezer Zut 6246. Superfreeze button won't go off
Probably is switch for fast freezing mechanically defective. Dado
1/16/2015 7:23:45 PM • Zanussi Freezers • Answered on Jan 16, 2015
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal temperature of the freezer will ensure the longterm conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound. You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once. When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food. Dado
1/16/2015 7:15:34 PM • Zanussi Freezers • Answered on Jan 16, 2015
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade). For a more precise answer I need more information. A lot of things may be incorrect: - Doesn't work defrosting cycle - The cooling fan is not working - Too much ice on the evaporator battery - Faulty thermostat or NTC sensor - Faulty cooling system (gas leak) - Compressor - Electronic Dado
1/16/2015 7:06:14 PM • Zanussi Freezers • Answered on Jan 16, 2015
Door will not close
It sounds like the door got shut when something in the jam and you may need to loosen the hinge, realign the door and tighten the door hinges again. Easier with 2 people but not impossible with 1.
3/3/2014 11:17:33 AM • Zanussi Freezers • Answered on Mar 03, 2014
2answers
Our freezer has devoloped a problem in that it
the unit was still wet inside when you switched on the fast freeze,hence the frost and ice.
1/21/2013 8:54:15 PM • Zanussi Freezers • Answered on Jan 21, 2013
0answers
Zx99 fridge freezer not freezing and intermitent
Hello....Sounds to me like the fridge is getting low on refridgerant gas...If it is an older unit...it may have developed a leak over time and may just need a recharge.Get a quote from a repairman...most of the time..it is not very expensive to fix unless there is a problem with the compressor....I hope this was helpful....PEACE....
1/25/2012 9:06:34 PM • Zanussi Freezers • Answered on Jan 25, 2012
Zanussi 3.46 cu. ft. / 98 liter Upright Freezer ZF56SI Logo
2 questions posted
Top Zanussi Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Freezers
  • Zanussi Freezers
Most Popular Question
  • Freezers
