20 Most Recent Sunpentown WC-30U Under-Counter Wine & Beverage Cooler 32-bottles NEW Questions & Answers
Here is a link to the manual. I hope it helps, because it says nothing about putting on handle. Maybe pics will help.
http://site.sunpentown.com/wc-30U_manual.pdf
Sunpentown... | Answered on Jan 28, 2015
You should refer to the user manual to help you troubleshoot your equipment located Here: http://www.manualslib.com/manual/574948/Sunpentown-Wc-30u.html
I hope this helps!
Good Luck!
Rich Lilja
Sunpentown... | Answered on Jul 22, 2014
if you can afford a real standby genset id get one of those. reasoning is this way you do not have to store gasoline and rotate it every few months. and if you have a backup style genset you may not be able to get fuel for it when your supply runs out. that and you have to hook it up when the power goes out. safely hopefully. they are sized depending on the size of your power needs. most places that sell them will come to your house and tell you what youd need. easy stuff
Electrical... | Answered 13 hours ago
Building lighting plays the vital role while developing the decor of the building. Apart from the performance, building lighting influences the confidence, safety, and mood. If you have the clear idea about lighting types, fixture types, and lighting based on the site type, then it will help you much when you are going for building lighting. The article below will help you much to understand about these three major things in building lighting. First, let us discuss the typical building lights types. General or ambient lightings can illuminate your entire building. Valance lighting, cove lighting, sconces, chandeliers, soffit lighting are some of the examples of this type. To help you to perform your tasks such as cooking and reading, you can use task lighting.
http://greenlightnational.com/
Electrical... | Answered 16 hours ago
Yes you can. A fuse is a fuse. Ceramic is chosen because it is fine if it gets hot.
Electrical... | Answered 17 hours ago
Selective lighting (hue), always ON or there's another switch that turns off lighting. Studio, dark room, other.
Electrical... | Answered 19 hours ago
I am wondering if your charger is working properly.I had one I had to replace after so long.
Electrical... | Answered Yesterday
Hi.
The vast majority of the time(over 99%) it is either the magnetism on the alternator has dropped out or AVR failing. If flashing the generator does not solve the problem then replacing this should fix it.
Only replace the part with a quality Grade "A" replacement that is built for your Generator. Anything else could cause damage to your Alternator, resulting in the Alternator needing to be replaced and this is a very expensive! (We only sell grade "A" products.)
You will need to pull the part out and have it on hand when you order. Once you have identified if it is an AVR or a Capacitor, look up and purchase your replacement parts on our website.
Kind Regards
The Generator Guru Team
Generator Guru
Hi.
The vast majority of the time(over 99%) it is the just the AVR or Capacitor failing (depending on which is fitted to your Generator. 2 or 4 wires = Capacitor and Brushless alternator, 5 or more wires = AVR and Brushed alternator.) Replacing this should fix your problem.
http://www.generatorguru.com
If you need any further help our Generator Engineers are happy to assist you.
Kind Regards
The Generator Guru Team Generator Guru
Suggest you get a 4 pole switch. Might not be possible to use a 6 leg switch
Electrical... | Answered 3 days ago
Sunpentown WC-30U Under-Counter Wine & Beverage Cooler 32-bottles NEW Logo
4 questions posted
Top Sunpentown Electrical Supplies Experts
John Trevino
Richard Lilja
Richard Lilja
wadingriver
wadingriver
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sunpentown Electrical Supplies
Most Popular Question
put handle
  • Electrical Supplies
