20 Most Recent Compaq Armada E500 Notebook Questions & Answers
2answers
Blank screen
hi i am kishan, from india u r facing this problem so same problem is facing my customer so i think its problem of your lcd so u can do one thing \ back side of your laptop u will find vga port so do arrang one moniter(desktop) and attach it to your laptop vga port and then start your laptop and press alt+f5(simbol of external monitor) and u can dispay your windows on moniter now u can take your backup it will work but u shoud check your laptops lcd dispay regard .... take care
4/15/2024 3:40:10 AM • Compaq Armada... • Answered Yesterday
My compaq armada e500 is not opening my Sandisk thumb drive.
YES YOU FORGOT TO USE USB EJECT SO IT NAGGED YOU. IS THIS XP XP DOES NO SUPPORT MANY THUMB DRIVES. NOR OLDER OS OLD PENTIUM -iii RELIC PC WINDOWS 98 IT HAD NEW. YOU POSTED LACKING ANY OS, W98 IS DEAD.
2/7/2022 9:16:08 PM • Compaq Armada... • Answered on Feb 07, 2022
3answers
Can't log in without administrator password
When it is starting up windows go into setup. A computer always has some kind of override. You can hack computers with this so use it wisely. Go through each of those tabs on the top until you see accounts in them. You should be able to override the old password with a new one.
8/28/2015 3:24:58 AM • Compaq Armada... • Answered on Aug 28, 2015
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
2/26/2015 3:01:30 AM • Compaq Armada... • Answered on Feb 26, 2015
What is comparison of speed of a loptop
Various factors determine your Laptops speed. Processor type, amount of RAM, Graphics card and Hard disk drive. Simply swapping your hard disk to a solid state drive will triple the performance.
1/20/2015 9:50:17 AM • Compaq Armada... • Answered on Jan 20, 2015
Hard drive has no sound won't boot up
Try to boot on a live CD. If it's OK, then change the hard drive and install the OS.
5/15/2014 5:42:30 PM • Compaq Armada... • Answered on May 15, 2014
0answers
Replace backlight in compaq amarda 500
change the power module at the bottom of the screen
3/25/2014 9:28:23 PM • Compaq Armada... • Answered on Mar 25, 2014
2answers
I try to unmute my volume on my compaq presario
Try updating the hardware driver for it.
Assuming that you are using some flavor of Windows, and guessing it might be XP ....
Right-clickie your My Computer and select the last item in the list, which is called Properties.
Select the Properties tab that is labeled Hardware.
On the Hardware tab, there is a button for Device Manager - click that one.
Look down the list for something called Sound and click the + beside it. In that list, there should be one named something like Integrated Audio. It may have some little symbol next to it, like an ! or perhaps a red X ....
Right-clickie the Integrated Audio (or whatever its called) and choose the option for Update Driver. Allow it to search for the driver Automatically when the Wizard opens up ... it will connect to the internet, find a suitable driver for you, and install it.
That should fix it.
If that does not fix it, you may have an actual hardware failure. If Sound is important enough, you may wish to have someone actually look at it for you.
3/12/2014 1:52:45 PM • Compaq Armada... • Answered on Mar 12, 2014
0answers
Dell 1012 mini
just press f2 that it show bios setting
1/22/2014 6:59:50 AM • Compaq Armada... • Answered on Jan 22, 2014
I have a dell inspiron mini 1012 and when it
I've had one of these machines with the same message and I just change the HDD, reinstalled Windows and we're good to go.
1/1/2014 1:48:40 PM • Compaq Armada... • Answered on Jan 01, 2014
3answers
What is Dry Boot of laptop and how to perform it?
Dry boot is a way to reset HP laptops. Sometimes it works and sometimes not. Here is how to do it.
Disconnect the power cord, remove the battery, press and hold the power button for about a minute. Then re-insert the battery and power cord and try to turn it back on again.
If you are still having the same issue, remove the battery but leave the power cord and try to turn it on. Oh yeah, disconnect any USB devices and a monitor (if you connected a monitor to your laptop), make sure there is no disc in the drive either.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
8/2/2013 2:37:06 AM • Compaq Armada... • Answered on Aug 02, 2013
2answers
How can I adjust brigthness using other option than F9, because it does not work
Per the user manual, the brightness is toggled by holding the Fn Key and pressing F10. You post made no reference to the Fn Key being pressed. If using an external keyboard press scroll lock twice then F10.
Reference: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01124713/c01124713.pdf
6/3/2013 11:14:38 AM • Compaq Armada... • Answered on Jun 03, 2013
Permissions access
Try this: Start > Control Panel > User Accounts > Change Your Account TypeMake sure the current account you are using is the administrator.
4/23/2013 4:37:25 PM • Compaq Armada... • Answered on Apr 23, 2013
Compaq Armada E500 Notebook Logo
450 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
dry boot laptop perform
  • Computers & Internet
