20 Most Recent
Konica Minolta bizhub 420 Questions & Answers
Error 2803 konica minolta 500
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
C2702 on bizhub 420
Check the transfer and seperation assy. located on the right side door. has a plastic screen below the screen are two wires very thin might be broken shooting out the HV board and or main board remove the assy and replace the wires first Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How to find bizhub 420 problem with code 1102
C-1102 is a tray lift motor failure. Your copier is equipped with a FS-511 finisher. The trays on the left side (where the paper comes out) is being blocked when its trying to move up/down. Ensure the are no obstructions an restart your machine.
