20 Most Recent
Konica Minolta Bizhub C280 Color Copier / Printer / Scanner Questions & Answers
When my konica minolta c280 gives me an error codes c2151 please help"
Code
C2151
Description
Secondary transfer roller pressure welding alienation
• The pressure welding alienation sensor doesn't turn OFF (retracting) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is retracting. • The pressure welding alienation sensor doesn't turn ON (pressuring) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is pressuring
Printhig is not good
What is the problem? Printing is not good does not really halp much.
If there are fine white lines on the paper, where there shouldn't be any, that ususall indicates blocked nozzles on the printhead. Swears could indicate fluff under the print head. Blotches could indicate wrong paper for your settings..... Please specify more clearly.
Light print color
besides the obvious of changing the toner cartridge, is the print drum clean? Pop the machine open and look at the drum...is it all dirty looking? If it is, it will affect the quality of the print...although you would see spots and other things appearing in your printing if that were the case too... the fuser may be dirty too..(the part that gets hot) and that can affect it too..
