20 Most Recent Epson Aculaser C1100 Printer Questions & Answers
Epson c1100 e door open
Just solved the same problem. It is a very slight misalignment of the two rollers behind door E. I closed door E holding the vertical bar below the handle and just 'jiggled' it slightly from side to side, and it latched closed. Paper jam fixed, yippee!!
11/15/2021 7:54:22 PM • Epson Aculaser... • Answered on Nov 15, 2021
2answers
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
10/21/2021 10:52:18 AM • Epson Aculaser... • Answered on Oct 21, 2021
2answers
Epson AcuLaser changé photoconducteur et
salut ;
ce message apparait lorsque le detecteur de photoconducteur est bloque avec du toner, desinstaller le photoconducteur ; nettoyer le detecteur situe a l'interieur.
8/16/2019 7:57:03 AM • Epson Aculaser... • Answered on Aug 16, 2019
0answers
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
9/2/2017 6:35:27 PM • Epson Aculaser... • Answered on Sep 02, 2017
4answers
Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
Re-attach Photoconductor Unit.
Does the error recur when the power is turned
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Is the Drum of Photoconductor Unit rotating?
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Remove Photoconductor Unit.
Turn gear of Photoconductor Unit until silver
seal attached to Belt can be seen.
Is silver seal dirty?
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Is SENSOR TR-0 attached securely?
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Are there any dirt or foreign bodies on the
SENSOR TR-0 surface?
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
The voltage of P416-2 ↔ P416-3 on PWBA
MCU is 5 VDC when silver paper or other
reflective object comes close to the sensing
area of SENSOR TR-0, and is 0 VDC when
the object is released?
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
The voltage of P416-1 ↔ P416-3 on PWBA
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
Disconnect the P/J416 from PWBA MCU.
Do all of the wiring below have normal
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
11/10/2016 6:34:53 PM • Epson Aculaser... • Answered on Nov 10, 2016
Service req e513
hello please I want to know the following error (Service Req C 513) thank you.
10/10/2016 11:34:50 AM • Epson Aculaser... • Answered on Oct 10, 2016
0answers
2answers
Hi there my c1100 acuslaser shows
Near Secunderabad , There is Paradise Restaurant beside it there is CTC , at that place you can get what you want.
4/21/2015 2:24:15 AM • Epson Aculaser... • Answered on Apr 21, 2015
2answers
Paper jam and E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson.
2/11/2015 11:18:35 AM • Epson Aculaser... • Answered on Feb 11, 2015
I have had the the error message just come onto my printer , no warning nothing e547 ???? How can i fix this ??
http://www.fixya.com/support/t154259-paper_jam_e547
2/11/2015 11:06:03 AM • Epson Aculaser... • Answered on Feb 11, 2015
9answers
Changing toner cartridges
Go to reset menu on printer LCD Panel
Hit enter button
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening!
11/29/2014 10:18:22 AM • Epson Aculaser... • Answered on Nov 29, 2014
How do you replace an Epson c1100 developer unit, please?
1. Open the front panel - named A 2 Inside you will see the empty cyan toner cartridge in its place. 3. To release the old cartridge and seal it, take hold of the blue part of the cartridge on the right hand side, and move it upwards as far as it will go. 4. The old cartridge will now move freely, as you move it towards you and out of the printer. 5. Package it safely as the toner is dangerous if inhaled. 6. Take the new cartridge and shake it a few times to distribute the toner evenly. 7. Remove the seal and tape, and discard. 8. Slide the new cartridge in gently and evenly. 9. When it has clicked into place, take hold again of the blue section, and roll it downwards to lock it into position. 10. Close panel A, and the printer will take a minute or two to warm up, reload the toner and prepare itself for printing. 11 NOTES : The only complications I have found are in getting the new cartridge to slide evenly into its proper location. If it is not in correctly, you cannot close panel A and it is just a question of sliding the cartridge out and retrying it. The other issue is to avoid the instinctive reaction of turning the printer off before you start working inside it!! The printer is best left on through this process and there is no risk as you do so.
9/8/2014 11:21:37 AM • Epson Aculaser... • Answered on Sep 08, 2014
Where can i find a epson Aculaser Y dev unit from please
The Y toner cartridges are still being produced by Epson. However not many stores in UK stock them. They are readily available on eBay. You will have a choice of originals or compatibles, and a choice of standard or high capacity cartridges. I normally stick to originals, and pay around 20 UK pounds for standard and 40 UK pounds for high capacity ones. Compatibles are about half of those prices, but I have found wide variation in quality. If you are not using a lot, then originals are preferable. Let me know if I can be of further help Trevor
8/17/2014 1:05:43 PM • Epson Aculaser... • Answered on Aug 17, 2014
0answers
Epson Aculaser C1100 Printer Logo
581 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
service req c0082
  • Office Equipment & Supplies
