20 Most Recent
Fujitsu Siemens AMILO Pro V2000 Notebook Questions & Answers
I had XP on the amilo pro, connected to talk talk
Open the Network settings and show available networks. Select the available network and when asked to insert the Modem Authorization data, type in the WiFi password.
The password should be on a label attached to the modem.
To fix mouse pad
Before you dismantle your laptop, check that the pad isn't disabled. Go to control panel and click on Mouse, the mouse pad configuration should be in there. turn it on. also look for it in Device manager (right click on my computer, go to properties) make sure the mouse pad has a driver loaded and it's working.
Connect my fujitsu siemens v3515 to a nobo s-17e projector
hi
hold down the blue lettered function key "fn" located 2nd left on bottom row....the press the function key F3 / F4 / F5 / F6 whichever one has the small icon that looks like a square/rectangle....it toggles in3 positions so if it dosent work first time press the same keys again...make sure your projector vga cable is connected to the correct vga input socket and select the input device on the projector to computer and not video
Download
ok...it is possible that the security settings are too high on your browser..check those in preferences through Internet explorer, and set them to medium
Fujitsu siemens lifebook a1220 master bios password
1. Exit Windows or reboot to the native MS-DOS mode,
2. Using the "Command prompt only" option from the Windows Startup Menu (hold Shift and F5 at the same time while your PC boots).
a) At the C:\> prompt, type: DEBUG
b) Press <ENTER>.
c) You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
(which will show as -o 70 2e at the DEBUG prompt).
d) Press <ENTER> and then type:
o 71 ff
e) Press <ENTER> and finally type:
Q
f) Press <ENTER> one last time, to quit DEBUG, back to the C:\> prompt.
3. Now you're ready to reboot your PC
a) Press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup.
b) You'll notice that the password is gone. :)"
