20 Most Recent Fujitsu Siemens AMILO D-7830 Notebook Questions & Answers
I disassembled the computer for
You may be better off just buying a new keyboard.
5/23/2017 5:33:04 PM • Fujitsu Siemens... • Answered on May 23, 2017
Fujitsu siemens Amilo D 7830 CMOS battery keeps dieing
As an update to this, I've been able to boot it up a few times since posting this, but it never gets as far as being able to boot up an entire operating system before freezing.
2/9/2015 11:03:24 AM • Fujitsu Siemens... • Answered on Feb 09, 2015
How do i restore my fujitsu siemens amilo laptop to factory settings without the cd
hi, if your laptop has the manufacturer installed recovery partition.in system restore sellect this.you will get a warning saying that all data will be deleted.press ok. restart.windows will be as was on the day you got it.
7/17/2014 12:40:07 PM • Fujitsu Siemens... • Answered on Jul 17, 2014
Wallpaper and icons/text is diplayed enlarged.
right click on Desktop then click properties. across top you will see several tabs. click on Setting. on lower left side you will see screen resolution. move the bar to the left and click ok on size you prefer. you can move this bar until you get the size you want 800X600 or 1024 x 760 would be the first ones to start with
5/5/2014 7:14:46 PM • Fujitsu Siemens... • Answered on May 05, 2014
Bios amilo xi 2528
Press F2
4/18/2014 2:15:11 PM • Fujitsu Siemens... • Answered on Apr 18, 2014
Language is swedish instead of dutch
Click start control panel, regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language alsoyou might need to download the language pack from microsofthttp://windows.microsoft.com/en-US/windows/downloads/languages?WT.mc_id=MSCOM_EN_US_DLC_AO_131W4ENUS26674
11/26/2013 10:32:07 PM • Fujitsu Siemens... • Answered on Nov 26, 2013
0answers
2answers
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
1/18/2013 1:22:40 PM • Fujitsu Siemens... • Answered on Jan 18, 2013
Microphone does not work
Go to control panel click on sound then click on the recording tab choice which ever mic you are using the click on properties then check the mic volume and see if its mute.
9/25/2012 2:15:40 AM • Fujitsu Siemens... • Answered on Sep 25, 2012
2answers
Factory reset
to factory reset a laptop you will have too hold some F keys(for example F8), it says how in the manual that came with the pc
7/31/2012 8:35:04 PM • Fujitsu Siemens... • Answered on Jul 31, 2012
PCI bus 0, device 31, function 6 driver code 28
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions they will automatically search for and find the correct driver also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name sound drivers you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/ free program, paid update available
hope it helps
7/17/2012 12:29:44 AM • Fujitsu Siemens... • Answered on Jul 17, 2012
What cause a laptop not to boot or show any
A failed motherboard or hard drive. Memory can play a role as well but generally you will hear a bleeping sound if that was the case. Does it still power on?
3/19/2012 10:32:57 AM • Fujitsu Siemens... • Answered on Mar 19, 2012
How do i restore my fujitsu siemens amilo 7850 laptop to factory default settings
But before you do this remember that restoring the laptop to factory settings.... All of the data on your laptop's hard drive will be permanently erased when you restore it to its original settings. Before starting the restore process you may want to save any data you still need to an external drive such as a USB flash storage device.Place the operating system recovery CD that came with your computer into the CD or DVD drive. Restart the computer.Wait for the computer manufacturer's logo to pop up on the screen. Press the keyboard key that brings up the recovery menu, which is usually "F2," "F8," or "Ctrl" and "F11" pressed simultaneously.Select the specific language you want the operating system to use from the menu at the top of the screen. Select "Next."Choose the option labeled "PC Restore," "Repair Your Computer" or something similar. Click "Next."Select "Restore" and then click "Enter" to start the process. Click "Restart" once the process has ended to boot the restored computer to its operating system.
2/22/2012 4:09:26 PM • Fujitsu Siemens... • Answered on Feb 22, 2012
Fujitsu Siemens AMILO D-7830 Notebook Logo
270 questions posted
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Siemens Computers & Internet
Most Popular Question
bios amilo xi 2528
  • Computers & Internet
