20 Most Recent Gateway 2520915 Keyboard Questions & Answers
2answers
Can you show me the ThinkPad from Lenovo and tell me how to acces the slash key
They key is on your keyboard and you don't need to use the Fn key. As an alternative run osk.exe (On_Sreen Keyboard)
1/4/2023 6:22:31 AM • Gateway 2520915... • Answered on Jan 04, 2023
2answers
Wireless Keyboard not connecting
Check driver for it
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
4/25/2021 12:11:22 PM • Gateway 2520915... • Answered on Apr 25, 2021
My keyboard is not working!!?? :(
yikes it seems as if the keyboard themselves are damaged and need of replacement though you maybe able to use a USB plugged keyboard (or PS/2 keyboard if supported) but it does seem those keyboards are ruined
3/14/2017 2:03:12 PM • Gateway 2520915... • Answered on Mar 14, 2017
8answers
Gateway keyboard types wrong characters
Same keyboard, same problem for almost 2 years now, and just now figured out how to fix it!! Try a simple left ctrl-shift, your language tab up top will switch between US English/Canadian English/Canadian multilingual, or whatever you set it for. I occasionally want the alternate characters applied, so now I can switch back and forth easily. You may need to set the language tab to your preferred settings. Hope this helps!
2/18/2015 11:14:20 PM • Gateway 2520915... • Answered on Feb 18, 2015
Cnet.com Password Sign In not accepting my former password in order to enter new. However, of the two earlier, both of whichi are accurate and, I've tried everything I can, but the old password, can't
Open a document and type the passwords you are trying into it. This is to verify that the keyboard keys you are using actually work.
7/1/2014 4:11:55 PM • Gateway 2520915... • Answered on Jul 01, 2014
Where is the Gmail "Forward" key or button located at website?
When you are in Gmail on the web click the "More" button and you will find the Forward option. Here is a picture of the "More" dropdown button, it is the one shown circled in red below.d94e8fd5-046a-444d-966f-fdbf4edb4f08.jpg
5/1/2014 1:09:34 AM • Gateway 2520915... • Answered on May 01, 2014
My Gateway laptop - 2 yrs old - just developed
Sounds like you have turned on the NUM LOCK on the laptop keyboard. If you look closely you will see the numbers on those keys (maybe in a different colour).
You need to turn off NUM LOCK again. On the laptop I'm looking at, this is done by pressing Fn and END together, but the key should be marked with NUM LOCK as well.
4/23/2014 3:46:47 PM • Gateway 2520915... • Answered on Apr 23, 2014
My hp laptop keyboard is not working. why
Could have died a noble death. Try plugging in a usb keyboard. If that works stay with it because laptop parts are expensive and the repairs are labor intensive.
2/23/2014 6:38:20 PM • Gateway 2520915... • Answered on Feb 23, 2014
Recently, and even after reinstalling windows, the keyboard has malfunctioned, and I often have to hold down the function key while typing in order to produce the correct key on the screen. The keys a
If your operating system is working correctly and you said you just installed it, you need to replace the keyboard it's defective.
12/13/2013 10:12:16 PM • Gateway 2520915... • Answered on Dec 13, 2013
Computer only buzzes doesnt get past start up page
Buzzing usually means one of two things: you have a bad CD/DVD in the CD/DVD drive (which would not usually interfere with booting up so that's probably not it in this case) or you have a bad hard disk. Try putting your Windows installation CD into the CD drive and booting from that. If the computer boots successfully, you have a bad hard disk. In that case, you will probably have to get a new drive and take the old one to a pro to recover any important data.
12/12/2013 4:41:22 AM • Gateway 2520915... • Answered on Dec 12, 2013
2answers
I cant get my 'at' key to work.
Try using the other shift key. If that works, then you most likely have a dirty or defective keyboard.
Does the number 2 work? Does your shift key product uppercase letters (does it work with other keys?)
If you are having problems with a flaky keyboard, it's pretty inexpensive to replace it and reduce your stress.
11/5/2013 9:42:16 AM • Gateway 2520915... • Answered on Nov 05, 2013
2answers
Keyboard beeps when any key is pressed
The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
10/3/2013 2:18:22 AM • Gateway 2520915... • Answered on Oct 03, 2013
E key not working on gateway lt20 netbook windows
Keyboard language problem using shift keys (getting blue letters)-On taskbark, click keyboard icon...
  • RightClick turn off AUTOADJUST
  • LeftClick change to US language
9/18/2013 5:18:21 PM • Gateway 2520915... • Answered on Sep 18, 2013
Missing letters when typing, slow register to screen
the best thing to do is set the delay on your kboard by your control panel-keyboad-thenn select an option.. hope this will help
8/26/2013 11:24:02 AM • Gateway 2520915... • Answered on Aug 26, 2013
Gateway 2520915 Keyboard Logo
389 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
keyboard beeps when any key pressed
  • Computers & Internet
