20 Most Recent Indesit WA 125 Front Load Washer Questions & Answers
2answers
I've washed some jewellery in washing machine!!
You might be able to pop the very top off the agitater,unscrew the nut and pull it up,your jewels will be under it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
12/6/2022 7:10:19 AM • Indesit WA 125... • Answered on Dec 06, 2022
INDESIT EVOLUTION 1200 WE125 WASHING MACHINE
Pressure switch not sensing correctly, this being the case, you will need an engineer.
10/30/2022 8:11:34 AM • Indesit WA 125... • Answered on Oct 30, 2022
0answers
Washes but won't spin. how do I open the filter
Not spinning is usually a broken belt/pulley. You can check by taking off the top of the WM, usually just 4 screws on the side (sometimes hidden below white covers). 25702038-cluqxvqmjdhmibjs3bae0uvv-4-0.png It could also be the (carbon) brushes that are worn down. 25702038-cluqxvqmjdhmibjs3bae0uvv-4-1.png Check out this video or a similar one for your make of washing machine. If you're handy you can replace them yourself after checking IF they are worn down (usually they decrease in length, check against image of "new ones"). I get my spare parts from http://www.europart.nl/wasmachine+onderdelen How to replace washing machine carbon brushes on Bosch washer
5/18/2015 9:44:13 PM • Indesit WA 125... • Answered on May 18, 2015
Hotpoint washer wt960 no display or power
there is many thing first check power if is ok then check his fuse open his penal fuse and supple.
6/19/2014 3:46:04 PM • Indesit WA 125... • Answered on Jun 19, 2014
Cant get pump out of the machine
go to appliancerepair.com
4/12/2014 1:37:00 PM • Indesit WA 125... • Answered on Apr 12, 2014
0answers
I have a Indiset Evolution 1200 WE125 F 12
F12 = communications error. one PCB is not speaking to the other. Can be anything from bad connections to failure of the electronics.
12/9/2013 1:35:12 PM • Indesit WA 125... • Answered on Dec 09, 2013
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
11/25/2013 11:54:39 AM • Indesit WA 125... • Answered on Nov 25, 2013
My washing machine is leaking from the fabric
This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
8/5/2013 6:04:57 PM • Indesit WA 125... • Answered on Aug 05, 2013
2answers
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
7/30/2013 1:37:02 PM • Indesit WA 125... • Answered on Jul 30, 2013
2answers
I need to replace the seal round the door but cannot remove the old one
Take the top panel off by removing the two screws underneath the lid at the rear and look down inside towards the front door edge of the drum you will see a very large metal hose clips holds the door seal on. A screwdriver will loosen the clip then the clip will slip off and then the seal can be removed and replaced
4/7/2013 9:29:34 AM • Indesit WA 125... • Answered on Apr 07, 2013
Where is the heating element in washing machine
What is the model number of your unit?
11/2/2012 3:51:41 AM • Indesit WA 125... • Answered on Nov 02, 2012
Locked
1) lock is defective or 2) the key is defective, see if some locksmith can make a new one. however you can bypass the lock key for to see if the machine will be RUN. Otherwise the problem is another place see the diagram attached. God bless you6_21_2012_6_03_17_pm.gif
6/21/2012 6:03:34 PM • Indesit WA 125... • Answered on Jun 21, 2012
Indesit WA 125 Front Load Washer Logo
148 questions posted
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Indesit Washing Machines
Most Popular Question
fabric conditioner not going
  • Washing Machines
