20 Most Recent HP Officejet Pro 8600 Plus e-All-in-One - multifunction fax / copier / printer / scanner color Questions & Answers
Hp officejet pro 8600 plus. why does it only print in black ink? cartridges are farely new.
check printer settings and ensure that the print color is ticked
10/28/2016 5:12:02 AM • HP Officejet Pro... • Answered on Oct 28, 2016
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges. Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
8/31/2016 10:13:16 PM • HP Officejet Pro... • Answered on Aug 31, 2016
Paper size mismatch
1. Measure the paper you are using. A4 or Letter. 2. Set your printer driver default (on the computer) to the size in step 1 3. In each of the program like excel, word or adobe, remember to check page setup and make sure the size is that same as the paper size.
5/28/2016 12:32:08 PM • HP Officejet Pro... • Answered on May 28, 2016
How to print labels
Use Avery Label sheet. Set correct paper size on Word and the Operating system. Use label from Sheet feed tray only. According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported; HP Officejet Pro 8600 All in One Printer series N911 Manuals 26130770-ainbrpw2kak424arn52muvwz-2-1.png
3/15/2016 4:18:39 PM • HP Officejet Pro... • Answered on Mar 15, 2016
0answers
Replaced Cyan ink and now it will not recognize. Brand new cartidge
Did you use HP ink or generic? Generic inks will only be recognized if they have the chip that talks to the printer. That is not to say they won't work - you just will not know the level. If you did use HP you have to make sure you have removed the taped portions, and that it "clicked" when you put it in the cartridge. Also - double check you really put in Cyan, I have put in the wrong color in a slot and it will not recognize the cartridge - boy did I feel really silly that day!
12/10/2015 12:31:50 AM • HP Officejet Pro... • Answered on Dec 10, 2015
Hp 8600 lines on scanning and copying
Hi The link below, looks slightly odd, but takes you to a page on the HP website with several solutions to this problem and also lots of diagrams shoeing you how to implement their solutions - EmptyPortlet Hope this is helpful, if so would you please register that with Fixya Cheers
3/6/2015 5:44:20 PM • HP Officejet Pro... • Answered on Mar 06, 2015
How do I install a new ink cartridge in an 8600
Hi Rather than give you a long screed about the cartridge replacement, if you go to this webpage, it is a manual for your printer in pdf format which you can save to your computer for future reference: http://h10032.www1.hp.com/ctg/Manual/c03026243 The relevant page of the manual for changing cartridges is page 93 of the manual. This refers to the "ink cartridge access door". If it is not obvious where this on the printer when you look at it, then page 13 of the manual shows you where it is. Hope this is helpful, if so would you please register that with Fixya Cheers
2/18/2015 11:14:09 PM • HP Officejet Pro... • Answered on Feb 18, 2015
Squeaking when it scans
If its scanning well and is out of warranty ignore it. If its under warranty get it replace. Quite often its not a problem, or just the high resolution stepper motor Operating.
11/22/2014 3:36:55 PM • HP Officejet Pro... • Answered on Nov 22, 2014
My printer officejet 8600 plus won't power up. Checked all power supply.
unplug everything but the power cord. then see if it comes on
10/23/2014 1:52:46 PM • HP Officejet Pro... • Answered on Oct 23, 2014
HP Officejet Pro 8600 Plus e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
65 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
bought all new cartridges inserted way
  • Office Equipment & Supplies
