20 Most Recent
Panasonic Lumix DMC-LZ2 Digital Camera Questions & Answers
Hi, I have just purchased the lumix fz200 and have
Sounds crazy but just make sure yo have removed the lens cover. If it does not work then something is wrong with your Panasonic and i would immediately return it for a another new unit that works properly. You might want to check manual to see if you are doing something wrong but I don't think so.
Image 'melts' into
I think the technical term is 'ruined'. Cameras are not built to withstand such abuse. Repair is unlikely to be cost-effective, so replacement seems the only option, taking the cost out of the kids' pocket money.
I am curious, though - why on earth did you leave an expensive electronic device anywhere that they could get hold of it ?
Panasonic lumix dc vario can't download pictures onto computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Update firmware
There is no update for the DMC-LZ2 available If Panasonic has new firmware for any camera, it will contact all registered owners and tell where and how to get and install the update.
Be aware, you only can update a correct working camera. There is no way to update a camera that does not function for 100%
Disc error
What type and size memory card are you trying to use? The DMC-LZ2 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
DMC-FX55 memory problem
Press menu/set...playback menu....select "copy"
Make the choice to copy the internal memory to the card and select "yes".
