20 Most Recent
Summit Commercial Summit Professional Wine Fridge Questions & Answers
The unit is not cooling down.
is the unit running? are the fans running? if the fans are running then check to see if the comp is running. If the comp is running you have a more serious issue. if its not or nothing is running im suspecting a control issue
7/21/2014 7:52:35 PM •
Summit...
Answered
on Jul 21, 2014
How do you mount the door handle on the summit swc530lbist?
Open the door on it. Gently pinch the seal and pull on it while giggling it and it will eventually come out to expose the Chanel with two holes that expose the screw heads. Simply tighten on the handle from the backside and push the seal back in place and your done.
3/12/2013 3:53:43 AM •
Summit...
Answered
on Mar 12, 2013
We set the under counter
Probabily you want to set the thermometer. Most refrigerator thermostat come with actual temperature setting from thermostat dial but it just use range; cold-medium-off ( or 5...5..3....1..0). So for instance to get your refrigerator colder just set between medium - cold. If your thermostat defective , your refrigerator will work unpredictably. In this case you need to fix or replace the thermostat. Other hand you can follow the user manuals for more informations.
4/27/2011 10:27:19 PM •
Summit...
Answered
on Apr 27, 2011
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
