20 Most Recent Intuit QuickBooks: Premier Manufacturing & Whosale Edition 2005 (284224) for PC Questions & Answers
tip
Solving printing problems in QuickBooks
If you are having problems printing in QuickBooks, follow these simple instructions to set up your printer correctly.
Open QuickBooks
Go to "File" at the top left side of your screen & click on it
This will open a drop down list
Choose "set up printer" & click on it
This will take you to a list of forms printed in QuickBooks
Choose the form you want to print & click on it
This will take you to a place to choose & set your default printer
Find the box that has the current default printer in it & look for the arrow
Click on the arrow next to the box with the printer name
This will give you a drop down list of printers to choose from
Find the name of your printer on that list and click on it
Then save your choices by hitting "ok" and closing the box
Repeat these instructions for each form you wish to print in QuickBooks.
Quickbooks Premiere SITUATION: I receive purchase
Hi MCC726,
Good News, Yes, you probably have your inventory UOM (Units of Measure) set to single. If this is Quickbooks 2007 0r later version, it supports multiple UOM's.
To enable unit of measure follow the steps below:
  1. Click Edit menu > Preferences.
  2. Click Items & Inventory then click the Company Preferences tab.
  3. Click the Enable button.
  4. Select the mode that you want to use Multiple U/M Per Item.
  5. Click Finish then click OK from the Preferences window.
Now to set up your UOM's do the following:
  1. Click Home then click Items & Services.
  2. Click the Item button then click Edit Item (if you want to edit an existing item) or click New (if you want to setup a new item).
  3. In the U/M field, click the drop down box then click Add New.
  4. Select a U/M Type. ( In your Case it would be count)
  5. Select a Base U/M. The base unit is the smallest unit in which the item is stocked and counted.(in your case it will be each's)
  6. Add any related units. You will select and define here the number of base units it contains. For example, a case will contain 24 each.
  7. Select the default U/M for the Purchase forms and Sales Forms.
  8. Finally, enter the name of this U/M.
  9. Then Click FInish.
From now on all your P/O's that are coming in from your customers will automatically convert from cases, Then you can delete your custom field, unless you created that field to show up somewhere normal UOM's can't.
Good Luck, and let me know how it goes.
Thanks
Mark
12/15/2009 4:37:16 AM • Intuit... • Answered on Dec 15, 2009
3answers
Intuit Error 15243
Intuit Error 15243
QuickBooks Error 15243 by Dylan on January 27, 2019 in QuickBooks Help 0 QuickBooks Error 15243 Overview QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update. QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly. Causes of QuickBooks Error 15243 The various causes due to which QuickBooks error code 15243 occurs are mentioned below: ·Incorrect QuickBooks installation ·Intuit QuickBooks File Copy Service (FCS) is damaged ·QuickBooks FCS service is not enabled ·QuickBooks Payroll subscription has ended ·Damage in Company File ·User not logged in as an Administrator QuickBooks Error 15243 - Intuit FCS Service is Damaged QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application ·Go to the Start button ·Right-click on Computer/This PC ·Choose Manage option ·Go to Services & Application Tab ·Double Click on Services option ·When you see Intuit QuickBooks FCS, click on it ·Click on the General Tab ·Click on Startup ·Choose the Manual option ·Click on apply ·Choose Start & then Ok ·Now, Reopen your QuickBooks as an administrator ·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription. Resolve QuickBooks Error 15243 in QuickBooks Payroll ·Open QuickBooks ·Go to the Employees option ·Choose My Payroll Service ·Select Manage Service key ·Click on the Edit option ·Verify your Payroll Service key ·Choose the Next option & remove the check for Open Payroll setup- I want to start right now ·Select the finish option ·After the verification, Go to Employees ·Select Get Payroll Updates ·Download Latest Payroll Update for QuickBooks Desktop & Update Contact QuickBooks Support to Repair QuickBooks Error 15243 If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243. Common Errors like QuickBooks Error 15243 ·QuickBooks Error 15271 ·QuickBooks Error 15215 ·QuickBooks Error 15101 ·QuickBooks Error 15214 ·QuickBooks Error 15203 ·QuickBooks Error 15222 ·QuickBooks Error 15262 ·QuickBooks Error 15102 ·QuickBooks Error 15106
4/4/2023 7:35:27 AM • Intuit Computers... • Answered on Apr 04, 2023
2answers
Quickbooks error code 1712
Click the Apple in the upper left hand side of the screen. Select Shut Down. Ensure the box to re-open programs is NOT checked. Once the computer is shutdown, restart the computer. Attempt to open QuickBooks for more help visit QuickBooks Technical Support
4/3/2023 7:35:35 PM • Intuit Computers... • Answered on Apr 03, 2023
2answers
Change font size screen
For complete provided on Intuit site by Change your screen resolution .
4/3/2023 8:43:20 AM • Intuit Computers... • Answered on Apr 03, 2023
Quicken 2010 Print error Code
3/8/2023 5:00:13 PM • Intuit Computers... • Answered on Mar 08, 2023
Banking Error 185 Intuit
we can not help you with this problem
11/7/2022 9:53:52 AM • Intuit Computers... • Answered on Nov 07, 2022
2answers
Need a manual for Quicken
You may browse on how you can use your Quicken through Intuit's website from this LINK. Choose appropriate Operating System.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
10/5/2022 5:38:57 PM • Intuit Computers... • Answered on Oct 05, 2022
2answers
How to use the QuickBooks Connection Diagnostic Tool
Ways to Use QuickBooks Connection Diagnostic Tool Tap the Quickbooks icon in the first place. Make sure to not access the file that is corrupted. Tap on Utilities and then select Repair. Hit the Network Problems button. If you receive a message then just hit the Yes button. Regards, Rachel Gomez
9/1/2022 7:37:39 AM • Intuit Computers... • Answered on Sep 01, 2022
The file was not created with the U.S. version of
ask them Mercia Beukes wants answers to this question we are not them , so ask real QB, this. you are mixing app versions and data and countries wrong. only they can sort out that mess.
8/16/2022 5:13:26 PM • Intuit Computers... • Answered on Aug 16, 2022
3answers
I need a serial for intuit Quickbooks Enterprise Solutions Retail 10.0
Please call quickbooks (844) 414-4868 & have a tech help you so you dont loose sensitive info. SUPPORT NUMBER: (844) 414-4868
6/6/2022 11:21:05 AM • Intuit Computers... • Answered on Jun 06, 2022
Quicken Deluxe thinks I'm not connected to the internet.
You can be in Quickbooks without bring online, but in order to use help you must be logged in; however you should be able to get into the check register without beng online.
12/7/2017 2:01:25 AM • Intuit Computers... • Answered on Dec 07, 2017
Activation code
Contact Intuit for the validation code.
1/6/2017 8:31:26 PM • Intuit Computers... • Answered on Jan 06, 2017
How do I import information from one company file into another?
Intuit QuickBooks can export lists, such as customers, vendors, items... Under file choose Export.
Once the lists have been exported, they can be imported into another file.
6/29/2016 11:01:59 AM • Intuit Computers... • Answered on Jun 29, 2016
SparkRent has shut down its services and they are moving me to QuickBooks.
Hello Matt, I too felt the same way and I have migrated to SimplifyEm Pay Rent. They are offering a free migration package for SparkRent users. I have already started availing their services and I feel it's really good. It has a lot of other useful features too. You can visit this link for more info: http://www.simplifyem.com/pay-rent Sincerely, Sara Pay Rent Pay Rent Online with SimplifyEm com Pay Rent
2/27/2015 7:51:14 AM • Intuit Computers... • Answered on Feb 27, 2015
Exception EOLEsys Error
This may be indicative that the system has been hit by a virus. Run a good anti-virus program like malwarebytes., then reinstall the software. If it still fails, you may have registry damage that extends to the OLE library files and a full reimage of windows may be needed.
11/25/2014 6:53:53 PM • Intuit Computers... • Answered on Nov 25, 2014
Error 209 dowloading 2012 turbotax home and
This error is caused by damaged QuickBooks installation files or by Windows user permissions. so try to Restart the computer and update your QuickBooks. for knowing complete guidance over follow Intuit Customer Service .
9/18/2014 6:02:31 AM • Intuit Computers... • Answered on Sep 18, 2014
Is there addtional instructions on the Intuit Pro Books
For any help an support follow http://quickbooks.intuit.com/ .
9/18/2014 5:48:47 AM • Intuit Computers... • Answered on Sep 18, 2014
Intuit QuickBooks: Premier Manufacturing & Whosale Edition 2005 (284224) for PC Logo
2 questions posted
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intuit Computers & Internet
Most Popular Question
need validation code quickbooks pro
  • Computers & Internet
