20 Most Recent Icom IC-M505 - VHF/DSC Marine Transciever Questions & Answers
Icom ic-m505 refuses to scan. In the setup menu, there is nothing visible about dual or tri- scan!!
DUALWATCH/  Description Dualwatch monitors Channel on another channel; Tri-watch monitors Channel 16 call channel while receiving another is convenient for monitoring operating on another channel. DUALWATCH/TRI-WATCH SIMULATION Call channel Dualwatch Tri-watch • If a signal is received on Channel 16, Dualwatch/Tri-watch pauses on Channel 16 until the signal disappears. • If a signal is received on the call channel during Tri-watch, Tri-watch becomes Dualwatch until the signal disappears. • To transmit on the selected channel during Dualwatch/Triwatch, push and hold [PTT] .  Operation q Select Dualwatch or Tri-watch in Set mode. (p. w Rotate [CHANNEL] to select the desired operating e Push [DIAL•DUAL/GRP] for 1 sec. to start Dualwatch or Tri-watch. •"DDDU UUA AAL LL 1 116 66" appears during Dualwatch; " T TTR RRI II 1 116 66" appears during Tri-watch. • A beep tone sounds when a signal is received on r To cancel Dualwatch/Tri-watch, push [DIAL• DUAL/GRP] again. [Example]: Operating Tri-watch on INT Channel 25 Tri-watch starts. Signal is received on call channel. 25W25W INTINT DUPDUP TAGTAG TRITRI 1616 3434° 34.506N34.506N 123123° 23.236W23.236W UTCUTC 1212:00:00 TELEPHONETELEPHONE BUSYBUSY 25W25W INTINT CALLCALL DUPDUP TAGTAG TRITRI 1616 3434° 34.506N34.506N 123123° 23.236W23.236W UTCUTC 1212:00:00 INTLINTL Tri-watch resumes after the Signal received on Channel signal disappears. 16 takes priority. 25W25W INTINT DUPDUP TAGTAG TRITRI 1616 3434° 34.506N34.506N 123123° 23.236W23.236W UTCUTC 1212:00:00 TELEPHONETELEPHONE BUSYBUSY 25W25W INTINT DUPDUP TAGTAG TRITRI 1616 3434° 34.506N34.506N 123123° 23.236W23.236W UTCUTC 1212:00:00 TELEPHONETELEPHONE More user manuals on ManualsBase.com If not understand mail me [email protected]
4/25/2019 12:39:37 PM • Icom IC-M505 -... • Answered on Apr 25, 2019
Ic m505 not receiving
turn the squelch down? the RF gain down too do you have an attenuator turned on ?
2/11/2015 12:05:23 AM • Icom IC-M505 -... • Answered on Feb 11, 2015
ICOM IC-A24 VHF Air band handheld transceiver. It works great except the display is blank. Any suggestions?
There is normally an electrolytic capacitor on the back of the display that regulates voltage for brightness. Sometimes thy are easy to replace. Or give it to a radio engineer, or return it to Icom for repair. They would likely just replace the display module and board. Someone else reports low contrast. https://forums.radioreference.com/threads/ic-a24-screen-contrast.321716/ https://www.google.com/search?q=ICOM+IC-a24+blank+display ..
4/7/2024 6:42:59 PM • Icom Radio... • Answered on Apr 07, 2024
Why is my icom ic-718 hf radio stuck in tx mode?
It can be a few things but first try resetting your CPU, while your transceiver is off, hold down the UP & DOWN buttons simultaneously then turn the transceiver back on, now it should be reset to the factory default settings
11/29/2023 11:26:24 PM • Icom Radio... • Answered on Nov 29, 2023
ICOM A210 aircraft radio transmits but is not recieving
The RX light should light up when receiving a signal. It may be your squelch setting is too high. Push the VOL knob until it enters the squelch setting, then set the squelch so it just cancels noise. If still not working you could have a wire broken in connector from headset that plugs into the radio.
7/31/2023 8:25:47 PM • Icom Radio... • Answered on Jul 31, 2023
How to calibrate my radio Icom ic-210e?
Send it in for repair. It is broken https://www.google.com/search?q=Icom+ic-210e
3/8/2023 6:47:15 PM • Icom Radio... • Answered on Mar 08, 2023
Remote key pad for IC-7610, I press a button and just get a beep like no memory is loaded, but memories on screen work.
If you're hearing a beep when pressing a button on the remote keypad for your IC-7610, it's possible that the keypad is not programmed correctly or is not communicating with the radio properly. Here are a few troubleshooting steps you can try:
  1. Check the connection: Make sure the remote keypad is securely connected to the radio's remote jack using the supplied cable.
  2. Check the settings: Make sure the remote keypad settings on the radio are configured correctly. Press the MENU button on the radio, select "Set" and then "Remote Operation." Check that the "Remote Type" setting is set to "IC-7610" and that the "Remote Address" matches the keypad's address.
  3. Check the keypad programming: Make sure the buttons on the keypad are programmed with the correct commands. You can check this by pressing the MENU button on the radio, selecting "Set" and then "Function Keys." The functions assigned to each key should be displayed on the screen. If they are not, you can program them by pressing and holding the F key on the keypad and then pressing the button you want to assign a function to.
  4. Reset the radio and keypad: Try resetting the radio and keypad to their factory settings. You can do this by pressing and holding the POWER button on the radio until it turns off, and then pressing and holding the FUNC button and the ENT button on the keypad while turning the radio back on.
If none of these steps work, it's possible that there is a hardware issue with either the radio or the keypad. You may want to contact the manufacturer's customer support for further assistance.
2/26/2023 4:15:17 AM • Icom Radio... • Answered on Feb 26, 2023
ICOM IC-R6 is scanning very slow. 1 frequency in 2 second, not 100 frequencies in 1 second. Where is problem ? How to change speed of scanning in IC_R6 ?
The Fix Programming via CS-R6 with Windows 10 made the problem. Scanning was very slow. The CS-R6 program through Windows 10 made problems with the scanning speed - it became very slow, one frequency in 2 seconds instead of 100 frequencies in one second. Through programming CS-R6 on Windows 7, the scanning speed returned to the corresponding one in the ICOM instructions - 100 frequencies per second
10/9/2022 9:56:12 PM • Icom Radio... • Answered on Oct 09, 2022
I finds very difficult to read a particular station in my icom 718
Hi, please move the radio away from it's current position to attempt to find alternative position where it's frequency will be transmitted clearly as intended. Also, please keep away from any microwaves or speakers so as not to cause any interference. Thank you.
6/14/2022 6:13:10 PM • Icom Radio... • Answered on Jun 14, 2022
Model 718. Why is CW mode kaput?
There are a few possible reasons why your radio might not be transmitting in CW mode. One possibility is that the keyer chip has gone bad. Another possibility is that there is a problem with the power supply. If you have a multimeter, you can check the voltages to see if they are within specification. Finally, it's also possible that there is something wrong with the antenna connection. Make sure that everything is securely connected and that there are no loose wires. I hope this helps!
4/23/2022 4:24:33 PM • Icom Radio... • Answered on Apr 23, 2022
Why won't my Icom AT-180 automatic antenna tuner tune at 21 or 18 mHz? Won't settle down and stop at low SWR.
Hi om sounds like you may have a break or something making that ant go haywire, have you checked all the line to see if there may be connection problem.another thing could you try the ant direct with a matcher inbetween to eliminate the auto tuner from circiut. This would narrow the fault down, have fun
3/26/2022 9:45:37 PM • Icom Radio... • Answered on Mar 26, 2022
Need icom software CS-F1000S and icom ic-f5023 v3.4 for downloading
Contact Icom to inquire.
2/11/2021 2:09:49 PM • Icom Radio... • Answered on Feb 11, 2021
Icom IC-M505 - VHF/DSC Marine Transciever Logo
2 questions posted
Top Icom Radio Communications Experts
eradiostore
eradiostore
Jim
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Icom Radio Communications
Most Popular Question
icom ic m505 refuses scan in setup
  • Radio Communications
