20 Most Recent Intel Motherboard Questions & Answers
4answers
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
3/14/2024 9:45:14 AM • Intel... • Answered on Mar 14, 2024
I945lm4 ver 2.2 front panel motherboard manual
ZxI945lm4
11/13/2022 5:59:28 PM • Intel... • Answered on Nov 13, 2022
3answers
Intel dg 41 rq audio not working
Check the bios to see if its not Disabled
Check on the control panel, Device Manager and see if its installed if not Try this link
http://downloadcenter.intel.com/Default.aspx?lang=eng
if none of this help you can install External card
5/5/2022 4:39:58 PM • Intel... • Answered on May 05, 2022
Intelr awrdacpi motherboard driver pack free download
z pilintra. that is not a PC maker names nor model that is not a real mobo number. the PC like that is XP and is virus magnet are you asking for XP drivers no OS told at all and is first. awrdacpi +bios tag the bios tag is useless to identify any mobo or PC maker and model. the PC as makers name if you lost the PC casing or services tags say so if you bought a raw Mobo say so. if you look at any mobo is has sticker lables those are the true models, of mobo. post photo of your mobo and stickers.
1/20/2022 6:06:08 PM • Intel... • Answered on Jan 20, 2022
2answers
What is the processors that can be compatible for
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot. Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together. BrandsThere are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel. Every motherboard, regardless of manufacturer, has a socket that will accept a processor. IntelCommon Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479. Your motherboard and processor will be generally compatible if their socket types match. ... Intel Core 2 Quad Q9650 Processor Compatible Motherboards Hope this will help you and please don't forget to rate me. Thanks for using FixYa
12/28/2020 6:56:35 AM • Intel... • Answered on Dec 28, 2020
2answers
Alioth-50c r1 01g
What is the question?
9/28/2020 10:39:55 AM • Intel... • Answered on Sep 28, 2020
3answers
Socket 478 mpga builtin sound card driver
You can download the drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or
Vista version of the drivers that matches your Windows operating system.
Click on this link: -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
4/29/2020 12:18:35 PM • Intel... • Answered on Apr 29, 2020
6answers
Audio/sound driver for msi ms6561 745 ultra motherboard
hi
i don't have sound in my PC
2/25/2020 8:37:14 AM • Intel... • Answered on Feb 25, 2020
D945gccr MB NO DISPLAY I GUESS ITS BIOS PROBLEM
Maltesh,1) IF ALL of the LED (Lights) were on they would use less than 1 Watt of power.2) EACH fan uses 2 to 3 Watts of power.3) A typical Processor can use 51 to 125 Watts of power.Intel D945GCCR motherboard? Can use up to an Intel Core2 Duo E4700, (800MHz FSB), according to Intel Support,http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gccrAn Intel Core2 Duo E4700 can use up to 65 Watts,http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29Check the Power Supply. A Power Supply with a weak voltage power rail, will have plenty of power to light LED's, and maybe spin fans, but Not enough power to turn the Processor on.No processor, no computer.The computer isn't generating a video signal. No Signal to the monitor. Do you have access to a multimeter, or DC Volt meter?Test the three Low DC voltages coming out of the Power Supply.A) 3.3 Volt power railB) 5 Volt power railC) 12 Volt power rail (ALL are DC voltage)[ In comparison two D cell flashlight batteries store 3 Volts DC ]Need guidance with testing post back in a Comment.Or if you have a KNOWN to be good, and Compatible power supply, that you can borrow for a test, try it.Regards,joecoolvette
9/29/2019 4:37:56 AM • Intel... • Answered on Sep 29, 2019
Msi ms 7297 ver.2.1 front panel help
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels; PWR power RST reset HLED hard dive LED PLED power LED You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
8/30/2019 5:28:59 PM • Intel... • Answered on Aug 30, 2019
3answers
Download msi n1996 video dirver
i want to download msi u100x n1996 webcam driver
8/21/2019 2:07:24 PM • Intel... • Answered on Aug 21, 2019
2answers
Plz suggest a Graphic Card for mercury motherboard PI945GZD ?
The first link are the system requirements for Wolfteam the sec link will be to the reccomended video card granted you can go higher quality above and beyond this but this will play the game well providing that the rest of your system is up to par I currently have the same card and have no isses playing games such as battlefield MOHA NFS games wish the best of luck to you
System requirments: http://wolfteam.komsik.net/SystemRequirements.html
Reccomended VID card:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4680647&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
7/9/2019 6:46:01 PM • Intel... • Answered on Jul 09, 2019
2answers
Converting wmv files to vob
Do you have DVD burning software? If not, you can download software that converts and burns the files directly to DVD. Such software is Wondershare WMV to DVD Burner and other titles linked on this page (free trials): http://www.download3000.com/download_47402.html
7/5/2019 7:03:43 AM • Intel... • Answered on Jul 05, 2019
4answers
I need a wiring diagram for an acer aspire m1610.
Doesnt power off:
I think your front-panel cables arent connected properly. (the picture might be wrong, because not all front-panels are the same)
No video signal:
The problem isn't with your monitor, it's wth your video card, motherboard, CPU or power supply. Do you get the single beep at startup?
6/3/2019 2:33:22 PM • Intel... • Answered on Jun 03, 2019
2answers
Making DVD so that it can be played in DVD PLayer
Hi
Yes Nero will do that but you should have full version of NERO to write it as video DVD and select the speed as minimum that will play in your external DVD player
Thanks
Boopathy
5/22/2019 2:38:08 AM • Intel... • Answered on May 22, 2019
2answers
I need the manual for my motherboard
Hello, I think I found what you are looking for. Just copy and past the link http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&lang=en&product=391723&dlc=en& into your browser. This is all the specs and information on you computer. You can download the manual, Drivers and find all your specs.
Copy and past this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00068983&lc=en&dlc=en&cc=us&lang=en&product=391723 for all the information on your motherboard.
If this is not your exact motherboard I think this will put you on the right track to find it. I hope this information helps and you have a great weekend
3/18/2019 9:07:58 AM • Intel... • Answered on Mar 18, 2019
3answers
Computer wont boot and cant locate sata drive.
  1. You might try using a different power or SATA cable to the drive. One of them may be defective.
  2. If your BIOS cannot see it then Vista cannot see it. Check your BIOS settings....you might need to enable SATA in your BIOS
I hope this information will be helpful. Thank you for using FixYa!
3/10/2019 4:43:17 PM • Intel... • Answered on Mar 10, 2019
2answers
MSI N1996 motherboard with 640gig
hi there. this is all the info i can find.plus try the link at the bottom might help you out some more. If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
3/9/2019 5:18:01 PM • Intel... • Answered on Mar 09, 2019
3answers
Motherboard driver link in gigabyte 945GCM3 rev 1.0
i need intel 945GCp board driver cd...........
3/8/2019 5:24:37 AM • Intel... • Answered on Mar 08, 2019
5,393 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
processors compatible
  • Computers & Internet
