20 Most Recent
Aprilaire 5000 Air Purifier Questions & Answers
Aprilaire 5000 pre-2005 was having
Replace the Aprilaire #4598 Ionizer Frame Assembly to correct this condition and return unit to operation with the green light now illuminated.
I have had the Aprilaire
I think you would be better served, by directing your question to a Respiratory Specialist.
Nevertheless, thanks for choosing FixYa.
Green light won' come on after changed filter
When u changed the filter u most likely got the filter enclosure door back together wrong, there is a switch in the door that locks out power, remove the access door for the filter and make u don't see any broken parts, the carefully put it back together
I have an Aprilaire 700.
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
Sail switch
Current sensing relay
New filter causing eye irritation?
There were some problems where people used glas-fiber-islations as a filter (it could be yellow or white), the problem generated because air filters and isolations camed in more or less same packageing (people didn't know, or couldn't know the diference) if u rub the new filter and it starts hurting or burning finger's you have isolation, if not there could be a problem with chemicals that where in filter fiber's, you can leave it on sun for a few hour's and bring it back in
this is the best i can do to help you
