20 Most Recent
Samsung SCX-4100 All-In-One Laser Printer Questions & Answers
Samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
Scx 4100 scanner error
let me guess all of you have vista?
FCUK VISTA
just install windows xp
it will work on it
I can not detect my scanner
first check if the driver its suitable for the operation system you use...cause if the driver is for Xp and you upgraded to vista you may have to change it too..and the way around...after you are sure the driver is the right one ...go to device manager and look for the printer ...if you find it with a yellow mark ..it means its not installed even if the driver is ...click right on it into the device manager and choose update driver ...it will start a wizard that will actually install the driver into the system 32..divers...
Fuser unit failure #u1-2113
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Problem for scx 4100 printer
the fuser is the part that melts the toner on the page if you open the door on the back the part you see with the two rollers ione is orange the other has a teflon coating on it this is the fuser. they are no longer available
PC Print Pending Message Won't Go Away
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
