20 Most Recent Samsung SCX 4623F - multifunction fax / copier / printer / scanner B/W Questions & Answers
What could be the solution of door open, close it on samsung scx 4623 w printer?
This is common. Check the right side of the front door. It will not be flush with the main case. Just give it a wack. it will work then.
11/15/2021 6:01:22 PM • Samsung SCX... • Answered on Nov 15, 2021
Cants printing ..when start up show this massege "warming up please wait"
The fuser is not warming up. You will need a new one. Not easy to fit so best have an engineer do it.
8/2/2016 8:08:59 PM • Samsung SCX... • Answered on Aug 02, 2016
0answers
My printer is constantly jamming papers. What maybe the cause and how can I prevent or solve this?
Its possible the paper is not good for the printer or the internals are dirty. Check your printer physically and run the cleaning option and try again. To avoid a jam:
  1. Use only one kind of paper at a time in your input tray.
  2. Whether you have a single input tray in your printer's driver or many input trays, tell the printer what kind of paper you have in the tray: Most printer controls include a section or drop-down list where you can pick a paper by name, type, thickness, or other quality.
  3. If you aren't sure whether your printer takes a certain kind of paper, check its documentation.
  4. When you reload your input tray, pay attention to the tray's needs, such as how the paper should be loaded and whether the length or width guides need adjusting.
3/10/2015 5:55:02 AM • Samsung SCX... • Answered on Mar 10, 2015
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help: How to Scan from Printer to Computer How to Scan Document in Windows 7 Use your computer to print scan and fax
3/2/2015 10:05:44 PM • Samsung SCX... • Answered on Mar 02, 2015
What causes letters to fade 3 inches in from the left margin, in a vertical line down the page, and how can I fix it?
Does this happen when copying or printing or both? If both then likley you have a defective cartridge, or something in the printer is blocking the scanner. Try gently shaking the cartridge to see if that helps. If it does, then either the toner is clumping or the cartridge is getting empty. If this only happens when making copies then probably the scanner glass is dirty.
1/26/2015 8:59:35 PM • Samsung SCX... • Answered on Jan 26, 2015
I don't know what to do, keep having "open door. close it" error popping up after changing the toner
Put the old toner cartridge back to see if the issue is gone. IF it is then you can get another toner. Beware of non OEM toner. The other thing if the problem does not go away is to reset the power. You have to unplug the unit from the wall to do that. Let us know.
12/23/2014 12:18:33 AM • Samsung SCX... • Answered on Dec 23, 2014
Erro #04-001
The scanner part of the printer is messed up. HP says "LSU error: #04-001. Please turn off then on." LSU = Laser Scanning Unit.
10/7/2014 12:54:59 PM • Samsung SCX... • Answered on Oct 07, 2014
Why do I keep getting "Door Open Please close door"; red light keeps blinking and both doors are are closed
the sencor is dirt you need to clean it.
10/7/2014 11:02:53 AM • Samsung SCX... • Answered on Oct 07, 2014
0answers
0answers
WON'T PRINT - STARTS THEN STOPS WITH A MESSAGE
reset the manual feeder or tray 2.and chk the paper sprator
8/29/2013 1:11:29 PM • Samsung SCX... • Answered on Aug 29, 2013
0answers
Samsung SCX 4623F - multifunction  fax / copier / printer / scanner   B/W Logo
40 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
could solution door open close samsung
  • Office Equipment & Supplies
