20 Most Recent Breville JE98XL Juice Fountain Plus Questions & Answers
Model JB90B. Where can I get a manual?
Breville no longer exists as a brand.
3/14/2021 3:23:35 PM • Breville Juicers • Answered on Mar 14, 2021
Error message
I fixed my juicer that had this problem, the problem was the thermal fuse which is located directly on the motor with some plastic covering it. You can replace the fuse or do what I did and just cut off the fuse and attach the two wires together (no more fuse) and my machine now works again :)
5/25/2020 11:42:21 PM • Breville Juicers • Answered on May 25, 2020
How to Register a Breville Juicer Fountain for warranty.
Warranty not dependent on registration. Your receipt is the key to any and all warranty repairs.
9/10/2017 1:25:04 PM • Breville Juicers • Answered on Sep 10, 2017
I can feel very small pieces of fruits or vegetables left in my juice after juicing with Breville Juicer
There is no machine for consumers that takes out all the pulp.
2/18/2017 5:16:51 AM • Breville Juicers • Answered on Feb 18, 2017
Where could i get an instruction manual for a BJE400 Breville Juice fountain
https://www.breville.com.au/media/mediaappearance/2737/BJE410.pdf
8/18/2016 8:09:03 AM • Breville Juicers • Answered on Aug 18, 2016
Stopped working. Why is the LED flashing "E"?
1/10/2016 8:42:36 PM • Breville Juicers • Answered on Jan 10, 2016
Motor not turning a little hum
1/10/2016 8:36:14 PM • Breville Juicers • Answered on Jan 10, 2016
How do i get my breville juicer fixed
take it to an appliance repair shop, get a quote then if dearer than a new unit ,junk it
11/28/2015 11:41:53 PM • Breville Juicers • Answered on Nov 28, 2015
The wire basket of my Breville Juicer is rusted. is there a safe way to remove the rust or am I going to have to buy a new part? if it the the former, what should I use? if it is the latter, where can
I am not sure how rusted it is, but it should be fairly easy to clean. I would start with either distilled white vinegar or fresh lemon juice. You should have good results with either. Otherwise Breville does have an 800 number or just google the model number and part name, the part should be available.
2/19/2015 3:40:46 AM • Breville Juicers • Answered on Feb 19, 2015
I have been given a breville je14 juicer but do not know how to dismantle for cleaning can you help please.
I've found a site that has the instruction manual. It shows the seperate parts and gives a quick overview of which of these parts should be washed before first use. Hope that helps Page 6 of Breville Professional Juicer Instructions JE16 ManualsOnline com
1/13/2015 11:18:41 AM • Breville Juicers • Answered on Jan 13, 2015
How do I fix my breville 5 speed juicer? The speeds wont adjust anymore. When i go to increase speed nothing happens unless i apply pressure to the knob, it then increases to speed5, and then goes bac
Your speed control is going out. I get parts like that all the time from a company called Allied Electronics. You will need to remove the speed control and get the part number off of it first before looking it up or calling.
11/14/2014 1:49:20 AM • Breville Juicers • Answered on Nov 14, 2014
I tried to turn on
there is inside a thermal fuse and it could have blown if wet, can be replace it is 1/8 x 1/2 " long .inside the machine turns off everything when blown , and purchased @ Radio Shack for about $ 5-8 dlrs rated @ 8-10 amps , need more info , if this works for you >
9/18/2014 6:33:32 PM • Breville Juicers • Answered on Sep 18, 2014
Motor burn out
to clarify- I was just starting out this morning, juicing some carrots and heard a pop (carrot chunk hitting the inside of the pulp cover) and the machine stalled.
3/6/2014 5:18:19 PM • Breville Juicers • Answered on Mar 06, 2014
2answers
Breville Juicer not juicing properly
MY WIFE HAS ONE AND IT'S LIKE A LOOSE CANNON. IF IT IS LEAKING FEED IT
VERY SLOWLY.
11/7/2012 12:56:56 PM • Breville Juicers • Answered on Nov 07, 2012
Hi. I need an instruction manual for Breville JE24 Juicer.
Hi ShirleyI do not see the JE24 listed any where on the Breville Support website.Therefore, I suggest that you use their toll-free number (or email them) to aid you in finding your manual:http://brevilleusasupport.com/talk-to-us/Call them @ (866) 273-8455, Mon.-Fri. 8-5 Pacific time.Good luck!
2/13/2012 7:36:46 PM • Breville Juicers • Answered on Feb 13, 2012
Breville JE98XL Juice Fountain Plus Logo
6 questions posted
Popular Products
Top Breville Juicers Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Breville Juicer Expert? Answer questions, earn points and help others
View Most Popular
Breville Juicers
  • Breville Juicers
Most Popular Question
feel very small pieces fruits or
  • Juicers
