20 Most Recent
Zanussi zwh6160p Questions & Answers
Zanussi zwh 6160p
This is not a real solution because it is impractical. But it may work. The machine has different sensor. One or more and not receiving the proper signals. Some sensors are like push in buttons. If they are not pressed the machine won't work or will just jump to end cycle. Since you mentioned it does works when you move the machine. It indicates a sensor may be loosen the drum bounces and when cloth is unevenly distributed it hits hard and the machine makes loud noises BUMP BUMP so my theory is a sensor is loosen and needs to be reattach . Only do it yourself if you have some experience taking things apart. Good luck. Anyways my impractical solution was to put two pieces of wood in only 2 of the 4 corners of washer and trying it this way the drum will be tilt and has more chances of pressing sensor.
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty.
Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums.
Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
