20 Most Recent Husky HUS-CN15 Wine Chiller Questions & Answers
2answers
Set the temperature
I can't get my temps to adjust
1 stay warm
1 stays cold
10/20/2016 7:38:59 AM • Husky HUS-CN15... • Answered on Oct 20, 2016
I do not have power
Call your supplier
10/29/2015 10:01:19 AM • Husky HUS-CN15... • Answered on Oct 29, 2015
Fridge is not getting cold, fans are running and outside casing feels cold to touch but internal warm think faulty compressor how can check and how easy to chnge
If fans are running and compressor is not check to see if the unit has a starting capacitor for the compressor - check it for capacitance value and change if necessary. If still nothing, using a voltmeter check to see if current is reaching the starting windings of compressor. If nothing, then maybe the thermostat is defective. But if current appears at terminal and the start capacitor is good, then the motor has definitely gone to heaven. if compressor is running and refrigerator is warm, either the self defrost mechanism is not working or perhaps you may be in need of refrigerant. To change unit you need vacuum pump, solder and soldering equipment, schrader valve, refrigerant scale and refrigerant, gauges, rags, emery paper, etc.
8/28/2015 2:57:20 PM • Husky HUS-CN15... • Answered on Aug 28, 2015
Why are Both lights flashing on my huscn15?fan doesn't start either
The lights flashing made be signaling a trouble code. If you have the owners manual or can go to the mfg website and download the manual, you may be able to find the troubleshooting section for the correct solution.
7/7/2014 11:52:44 PM • Husky HUS-CN15... • Answered on Jul 07, 2014
0answers
0answers
0answers
0answers
Temperature
Be the first to answer 12/11/2013 3:32:05 AM • Husky HUS-CN15... • Posted on Dec 11, 2013Be the first to answer
0answers
The temperature will not adjust. none of the
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
8/14/2013 9:52:51 PM • Husky HUS-CN15... • Answered on Aug 14, 2013
0answers
0answers
Husky cn15 88 problem
First things first, check the power supply. If there is power at the pluf then I would look at the temperature control. Check to make sure it is closing and calling for the compressor to be coming on, that will also control the condenser fan motor. Good luck
9/8/2012 11:13:09 PM • Husky HUS-CN15... • Answered on Sep 08, 2012
Husky HUS-CN15 Wine Chiller Logo
28 questions posted
Top Husky Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Husky Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Husky Refrigerators
  • Husky Refrigerators
Most Popular Question
fridge not getting cold fans running
  • Refrigerators
