20 Most Recent
Kodak C1550 Digital Camera Questions & Answers
Revover photos
Hi, if you want to recover your android phone's lost photos, you can watch this video and try it.
Camera will no power on
Hi try charge your camera battery and check if it keep current, if yes it can be faulty circuit board if not replace battery. Check also if charger is working properly.
Why won't my digital camera connect to my usb and my pc
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
It says, whenever I turn on my camera that the
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens obstructed errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
How do you remove the battery from a Kodak Pixpro AZ528?
To remove the battery from your Kodak Pixpro AZ528 camera, follow these steps:
- Turn off the camera and remove any cords or cables that are attached to it.
- Locate the battery compartment cover on the bottom of the camera. It is typically marked with a battery icon.
- Slide the battery compartment cover open. It may be held in place with a small latch or tab that you will need to release before you can open the cover.
- Carefully remove the battery from the battery compartment. It may be held in place by a small latch or spring. Be sure to grip the battery firmly to avoid dropping it.
- Close the battery compartment cover and make sure it is securely latched.
If you have any trouble removing the battery or if the battery compartment cover is stuck, you may want to consult the Kodak Pixpro AZ528 user manual for more detailed instructions.
