20 Most Recent
Kodak EasyShare One Digital Camera Questions & Answers
MOV format
The MOV format is an industry-standard format used by many digital still-picture manufacturers. As with the JPEG format used for still images (the primary purpose of EasyShare cameras), the MOV format provides a video capture file that can be used on most computer operating systems and platforms.
Kodak EasyShare digital cameras include the free Apple QuickTime player software. If you are interested in more sophisticated editing capabilities, many MOV editors are available from several companies:
QuickTime Pro from Apple Computer Inc. is the initial upgrade package to the free QuickTime player software.
Search the Internet using the phrase "QuickTime editing" to find many other sources of QuickTime editing software with a wide range of capabilities.
I Downloaded my photos to my computer and when I
Remove the battery from the Camera then press and hold the power button for 30 seconds.
Then, reinsert the Battery pack and try to reset the camera to the original factory settings before using it.
Restore deleted pictures
If the pictures were on a memory card and you haven't done anything with the card since you deleted the pictures, you have a chance to recover at least some of them. Do a Google search for "data recovery software" and select a program appropriate for your computer and operating system. Put the memory card into a card reader connected to your computer and run the program.
Kodak easyshare V1253, 120
This is very upsetting for you, but unfortunately Fixya has no connection with Kodak. You may be able to get assistance directly from Kodak.
I have a Kodak C613 camera. Every time i connect
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
My camera doesn't come on
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries.
Hope this helps.
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
My camera erased my pictures
These cameras have an internal store and also can use a card. So, when you add a card, it is writing to that store and only shows you the pictures stored there unless you change the device settings or remove the card.
If so, the images you have on the EasyShare One internal store may be originals
Another possibility is that you did a BragBook synch to EasyShare and you might be able to see these images in your 'Favorites' view. The 'Camera Favorites' or BragBook pictures are a smaller version of original images, to allow you to carry more pictures with you to share, but these pictures may be a lower resolution version of the images you took. They would be sufficient for printing 4x6 pictures, but not enlargements.
Change to Favorites mode to see if they show up that way.
DigiChick.
