Kodak EasyShare Cameras • Uploaded on Jul 11, 2013
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras. 2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution. 3. Digital photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible. 4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo. 5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions
270 questions posted
601 Questions
559 Questions
492 Questions
428 Questions
435 Questions
