20 Most Recent Kodak EasyShare DX7590 Digital Camera Questions & Answers
2answers
Flash does not open when I slide the "open flash" switch.
Try gently lifting the flash with the flash latch held open. It may have grit stopping it or a broken spring. Also make sure the latch is pulling right across to the right.
11/28/2021 3:28:29 AM • Kodak EasyShare... • Answered on Nov 28, 2021
Why is my camera going round and round in circle when trying to format my memory card?
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
5/1/2016 8:21:06 PM • Kodak EasyShare... • Answered on May 01, 2016
How do i install a new sd card
Installing a new SD card is as simple as pulling the old one out and sliding the new one in. You may need to "format" the new card, using the camera's menus.
12/14/2015 7:56:57 PM • Kodak EasyShare... • Answered on Dec 14, 2015
Kodak DX7590 won't format sd card
Usually means the card is bad. Confirm it won't do _any_ cards. Then it's a problem with the camera, and it will be a circuitry issue... not easily repaired.
9/2/2015 4:34:21 AM • Kodak EasyShare... • Answered on Sep 02, 2015
Will my camera format a 16gb sandisk? If not what do I need? I can't find a Kodak sd?
Us a reader an format it. Camera may limitation on how much space it can read / write
2/13/2015 7:44:50 PM • Kodak EasyShare... • Answered on Feb 13, 2015
How do i remove the battery cover from my kodak easy share dv7590
from this manual: http://www.imaging-resource.com/PRODS/DX7590/DX75A.HTM is the following statement: On the bottom panel of the DX7590 are the metal tripod mount (kudos for the use of metal here), dock jack, and battery compartment. The threaded tripod mount is a little off-center and too close to the battery compartment for quick battery changes while working with a tripod. The battery compartment features a locking, hinged door, which slides to the side to open under spring pressure.
11/14/2014 4:29:08 PM • Kodak EasyShare... • Answered on Nov 14, 2014
2answers
Kodak dx 7590 camera will not format a memory card?
as a short cut try putting the sd card into your sd slot and format it with your computer
9/24/2014 3:52:27 AM • Kodak EasyShare... • Answered on Sep 24, 2014
The mode dial will not turn
Unfortunately this is a common problem. It can be repaired but repair will be about fifty dollars. One repair shop is: [email protected]
7/16/2014 12:57:10 PM • Kodak EasyShare... • Answered on Jul 16, 2014
0answers
0answers
Scratch in lens
Although it is annoying when you see a scratch, most scratches can't be seen on a picture. Unless it is very deep and in the centre. The only problem is, you easy can get a lens flare. If you can live with the scratch, forget that it is there and only avoid light shining on the front lens from the side. My DX7590, still has a perfect lens, but I can't shoot, because my mode dial and joystick don't work any more. I still enjoy the pictures I took with that camera.
1/30/2014 8:55:32 PM • Kodak EasyShare... • Answered on Jan 30, 2014
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
1/12/2014 12:12:58 PM • Kodak EasyShare... • Answered on Jan 12, 2014
Flash doesn't pop up
If you move the switch on the right of the flash, to the right, the flash still won't come out? That is how I have to open my flash on my DX7590
12/2/2013 10:02:43 PM • Kodak EasyShare... • Answered on Dec 02, 2013
0answers
Kodak EasyShare DX7590 Digital Camera Logo
135 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
scratch in lens
  • Cameras
