20 Most Recent Kodak EasyShare Z740 Digital Camera Questions & Answers
Blurry or dark pictures in low light
Low light= slow shutter speed = camera shake
Use a tripod
2/13/2024 6:35:16 AM • Kodak EasyShare... • Answered on Feb 13, 2024
2answers
How do I get a manual. My Daughter-in-law gave me
http://support.en.kodak.com/app/answers/detail/a_id/18570/kw/z740
5/20/2023 12:07:04 AM • Kodak EasyShare... • Answered on May 20, 2023
Hi, my Kodak EasyShare Z740 turns off after taking one picture, or even just by focusing.
That sounds like your batteries are worn out because they are rechargeable. The trickle charger doesn't have enough milli-amps to run the camera only to charge the battery. https://www.google.com/search?q=kodak+easyshare+z740+battery+replacement ..
3/2/2022 5:13:36 PM • Kodak EasyShare... • Answered on Mar 02, 2022
0answers
Starts, then stops.
Hello! Here is a link to the manual to this camera. Please check the "Troubleshooting" part. Hope it will help! https://manualsbrain.com/en/manuals/1876620/?page=47
10/27/2017 10:48:34 AM • Kodak EasyShare... • Answered on Oct 27, 2017
Memory card won't format.
Have you tried this card in any other device?
9/29/2017 3:50:49 AM • Kodak EasyShare... • Answered on Sep 29, 2017
My Kodak Easy Share z740 Digital Camera will not format ANY SD card. I am using a 2GB SanDisk card. HELP
Format card in your computer first, using FAT 32 then try again in camera
8/23/2017 3:23:40 PM • Kodak EasyShare... • Answered on Aug 23, 2017
Kodak Z740 all of a
An external reader is the best solution. It will transfer the images way faster than using a cable connected to the camera. See if there is a setup option in your camera that chooses the SD card only for storing photos. If there is, then select it.
4/15/2017 4:33:55 AM • Kodak EasyShare... • Answered on Apr 15, 2017
Blurry parts of pics
Sounds like subject movement. Try using a faster shutter speed
4/10/2017 3:50:45 PM • Kodak EasyShare... • Answered on Apr 10, 2017
Somehow i mistakenly changed the language to something i cannot understand..how do i change it back to english[kodak z740]
Press Menu, select the three-item icon, then select the ABC icon. If you need a manual, you may download a copy at http://resources.kodak.com/support/pdf/en/manuals/urg00330/Z740_GLB_en.pdf
1/30/2017 12:12:57 AM • Kodak EasyShare... • Answered on Jan 30, 2017
2answers
The kodak easyShare z740 camra i have purchesed will not turn on
For Z740 camera the batteries should be AA Ni-MH batteries it will provide a maximum power on the camera. Now if your using the battery and its fully charged still wont turn On.
To test your camera if its defective, Try to Turn On the camera using a 3V AC adaptor if this failed it means you need to send the camera for repair you may call kodak tech support toll free 1 800 235 6325 ext 12
9/12/2016 6:50:05 PM • Kodak EasyShare... • Answered on Sep 12, 2016
Keeps telling me to format memory card
The memory card might be bad. Try a new or different memory card and if those work fine, t is your card that's bad. Have you used this card in this camera prior with good results or is this the first time? Has the card been formatted on a different system or different computer prior and if so, there might be problems there and maybe if the card is good on other equipment, it might be relegated to just those. If you have data or photos on your card that you cannot recover yourself, you can try sending it out to a data recovery service you can find online. Hope this helps, Mike
12/13/2015 10:34:03 PM • Kodak EasyShare... • Answered on Dec 13, 2015
5answers
Cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
3/23/2015 12:29:44 AM • Kodak EasyShare... • Answered on Mar 23, 2015
What is the price
$349
1/19/2015 7:08:57 AM • Kodak EasyShare... • Answered on Jan 19, 2015
How to elete photos from Kodak Z740?
Hi The link below takes you to a web page which deals with picture deletion:- http://resources.kodak.com/support/shtml/en/manuals/urg00330/urg00330c2s5.shtml But this link below downloads a full manual for the camera, including picture deletion:- http://resources.kodak.com/support/pdf/en/manuals/urg00330/Z740_GLB_en.pdf Good luck
8/25/2014 8:05:22 PM • Kodak EasyShare... • Answered on Aug 25, 2014
I only have43 pic. on my memory card and it say it
64mb is a very small memory card..... my Canon might fit just 1 picture on there, with the 8gb, just follow the camera instruction to format it..... the camera wants to prepare the card for use.
5/25/2014 6:54:47 AM • Kodak EasyShare... • Answered on May 25, 2014
New memory card
because it's a Kodak..... and the easyshare range have so many faults.... have you tried updating the firmware?
5/25/2014 4:39:07 AM • Kodak EasyShare... • Answered on May 25, 2014
Will a 32 kg dane-elec memory card work with a Kodak easyshare P850?
No. The P850 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
5/22/2014 2:59:50 PM • Kodak EasyShare... • Answered on May 22, 2014
Kodak EasyShare Z740 Digital Camera Logo
410 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
format
  • Cameras
