20 Most Recent
Marvel 61WC Wine Cooler Questions & Answers
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
