20 Most Recent Daewoo KOR1NOA Microwave Oven Questions & Answers
Turn Table does not turn is it suppose to
One could unplug the power cord and take off the back metal panel.The turntable runs off a rubber belt.Be very careful as the capacitor holds one hell of a voltage. It is usually encased by a metal shield... but be very alert.Do not run the microwave with the cover off..
4/25/2012 11:13:13 PM • Daewoo KOR1NOA... • Answered on Apr 25, 2012
Heating up leftovers microwave got
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
7/28/2011 7:20:50 PM • Daewoo KOR1NOA... • Answered on Jul 28, 2011
Daewoo KOC-925T microwave/convection touchscreen will not work?
Take it to a Daewoo Service Centre, and they can get parts and you don't really want to be messing inside a Microwave.. In normal circumstances, with a cheap make like Daewoo, you just replace them, but get a quote. Help and videos in the link, if you choose to take the risk. https://www.google.com/search?q=Daewoo+KOC-925T+microwave%2Fconvection+touchscreen+will+not+work https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
4/11/2024 5:14:08 AM • Daewoo Microwave... • Answered on Apr 11, 2024
Daewoo koc-985t bi microwave oven lamp won't turn on, what kind of lamp should I buy?
take outer case off and find the light .
11/6/2021 3:00:40 PM • Daewoo Microwave... • Answered on Nov 06, 2021
Please, how can I set a Daewoo 6N9RR microwave oven cooking time to over 1 hour
try putting 90 in the time that should be 1 1/2 hours
4/17/2021 6:49:02 PM • Daewoo Microwave... • Answered on Apr 17, 2021
DAEWOO KOR-6L1B not working even when plugged
Check the rear for a screw cap fuse. If there isn't one, you need a Daewoo service centre.
11/30/2020 9:11:24 PM • Daewoo Microwave... • Answered on Nov 30, 2020
I have a daewoo microwave+oven.due to overheating microwave stopped while oven is still working.how can i repair microvave??
The voltages inside a microwave oven are very dangerous, potentially fatal, so clearly the testing and repair need specialist experience and test equipment... Anyone needing to ask the question clearly should contact their local repair shop.
3/22/2020 5:12:01 PM • Daewoo Microwave... • Answered on Mar 22, 2020
Daewoo KOR1N0A - part of the touch panel isn't responding, it's the lower keys (Power, 0, Clock) that I can't get to work even though I can feel a pressure pad depressing. Is there a replacement?
The key pad assembly is faulty as the carbon contacts get disconnected,the only remedy is the replacement of touch key pad.
3/4/2019 11:16:04 AM • Daewoo Microwave... • Answered on Mar 04, 2019
Daewoo KOR-7LREM Retro micro Sporadic:sometimes heats up the food & most of the time doesn't heat like it should-have to add time to the recommended time but getting increasingly unreliable.
Does it have a turn table that spins your food container? If so, does it turn? If not, you are getting a solid directed beam of microwaves focused on one part of your food leaving the rest of it ignored. If it doesn't have a turn table, it will have a wave spreader inside which is nothing more than an aluminum fan that is sometimes driven by a small motor and rubber belt. You won't see this as it is inside the chamber that contains the magnetron that generates the microwaves. These belts can break allowing a solid, focused microwave beam to shine on your food rather than be distributed around the oven, again, leaving the rest unwarmed. If this is the case, using the oven can damage it over time. If you don't know what you are doing, DO NOT try to repair it yourself!!! If you don't get the outer casing back together properly, you can expose yourself and / or your family to dangerous amounts of microwave radiation. You should take it to a qualified service center for repair but I would venture a guess that it is already damaged because of your statement "but getting increasingly unreliable". Even if it isn't damaged, it will probably cost you more in labor to fix it than it would cost to replace it. Good luck.
12/31/2018 7:52:28 AM • Daewoo Microwave... • Answered on Dec 31, 2018
Daewoo KOR1NOA Microwave Oven Logo
14 questions posted
Top Daewoo Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Microwave Ovens
Most Popular Question
turn table not turn suppose
  • Microwave Ovens
