20 Most Recent ASUS VW222U 22 inch LCD Monitor Questions & Answers
Asus vw222u only offers 800x600 resolution.
one way to is 60 hz
10/30/2014 5:31:46 PM • ASUS VW222U 22... • Answered on Oct 30, 2014
Hello, I have been using my
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
http://www.scan.co.uk/products/512mb-pny-nvidia-geforce-6200-graphics-card-agp-8x-4-cores-d-sub-dvi-i-s-video-passive-cooling
4/22/2011 11:57:44 AM • ASUS VW222U 22... • Answered on Apr 22, 2011
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
Need wiring connections for asus M4a785-m motherboard.
Visit M4A785-M - Support (asus.com) and download the required manual.
9/19/2023 12:31:26 PM • ASUS Computers &... • Answered on Sep 19, 2023
Asus rog rg8 ii dont power up
6/23/2023 6:50:54 PM • ASUS Computers &... • Answered on Jun 23, 2023
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem: 1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in. 2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable). 3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues. 4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations. 5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors. 6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable. 7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility. 8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement. Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
5/29/2023 7:54:59 AM • ASUS Computers &... • Answered on May 29, 2023
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed. Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy. The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways. Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue. Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month. Google Chrome Download - Download Google Chrome google.comhttps://www.google.com Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now Get a new and fast web browser. Download Chrome and start browsing.
5/1/2023 7:50:39 PM • ASUS Computers &... • Answered on May 01, 2023
I inherited an Asus UX50V with Linux installed and would like to restore it to Windows 7.
The restore disc should have Product ID Key and that is all you need. Any password is entered after the install IF you want it password protected.
3/8/2023 5:01:53 PM • ASUS Computers &... • Answered on Mar 08, 2023
Euro symbol on keyboard for ASUS
This is the Keyboard Shortcut 1. Using the Alt keyboard shortcut to add the euro symbol:
  1. Place the cursor where you want the euro sign to appear.
  2. On the numeric keyboard, hold down Alt while pressing 0128.
  3. Use the numeric keypad's NumLock button if the sequence doesn't work.
How to Type the Euro Symbol? - DataFlair
More here https://www.google.com/search?q=Euro+symbol+keyboard+shortcut ..
3/7/2023 7:24:55 PM • ASUS Computers &... • Answered on Mar 07, 2023
My asus laptop turns on but there is just black, the power indicator says its on.
If you are experiencing a black screen issue on your laptop, the first thing you should do is to make sure your laptop is powered up correctly. Check the cable from the power adapter to the laptop, and make sure it is firmly plugged in. If it is, then you should try resetting the power supply on your laptop. To do this, unplug the power adapter from the laptop, press and hold the power button for 30 seconds, and then plug the power adapter back in. If the laptop still does not display any images, you should try reseating the RAM chips. First, try to turn off and unplug your laptop, and then remove the battery. After that, open up the RAM memory slot, and use a screwdriver to press down on the RAM chip securely. Then, replace the RAM chips and the battery before turning on your laptop. If these troubleshooting steps do not work, then it is likely that your laptop may have a hardware issue, and you should take it to a repair shop.
2/24/2023 7:56:23 PM • ASUS Computers &... • Answered on Feb 24, 2023
How can I get into my Asus T100?
AS MAKER YET>? ASUS.COM FOR HELP I SEARCHED FOR YOU THERE AND GOT THIS. https://www.asus.com/US/support/FAQ/1046347
2/23/2023 3:30:42 PM • ASUS Computers &... • Answered on Feb 23, 2023
MY ASUS T100 keyboard is not working.
Double check that the tablet is sitting properly in the keyboard Is this the model where you can charge via the keyboard - plug the charger into the keyboard? Reply with more info
2/22/2023 5:48:18 PM • ASUS Computers &... • Answered on Feb 22, 2023
AMD Ryzen 5 5600G causes BSOD after instaling graphics driver
t is possible that the issue is related to a driver conflict or compatibility issue between the graphics driver and the operating system. Here are some troubleshooting steps you can try:
  1. Update the graphics driver: Download the latest version of the graphics driver from the AMD website and install it. This may resolve any compatibility issues that were present in the previous driver version.
  2. Run Windows Update: Check for any available updates for your operating system and install them. This can resolve any compatibility issues with the graphics driver and other system components.
  3. Check the device manager: Open the device manager and check if there are any issues with the graphics card or other devices. You may need to update or reinstall the driver for the device.
  4. Check the system memory: Use a memory diagnostic tool to check if the system memory is working properly. Faulty memory can cause BSOD errors.
  5. Check the power supply: Insufficient power supply can cause system instability and BSOD errors. Check if the power supply is adequate for the system configuration.
  6. Disable or remove any third-party antivirus or firewall software: In some cases, these programs can interfere with the graphics driver installation or cause conflicts with system components.
If none of these steps resolve the issue, it may be a hardware problem with the graphics card or the motherboard
2/16/2023 2:39:33 AM • ASUS Computers &... • Answered on Feb 16, 2023
Bad bios checksum on motherboard
Sounds like the wrong bios file has been installed. Try to reload the original, at least it worked.
2/14/2023 7:34:00 AM • ASUS Computers &... • Answered on Feb 14, 2023
I used jumper bios reset
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
2/13/2023 8:24:18 AM • ASUS Computers &... • Answered on Feb 13, 2023
ASUS VW222U 22 inch LCD Monitor Logo
Popular Tags
4 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus vw222u only offers 800x600
  • Computers & Internet
