20 Most Recent
Samsung PL120 Digital Camera Questions & Answers
Zoom did not operate normally,insert
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
Free software download
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa ( http://picasa.google.com ). Picasa can also do a more than tolerable job of editing and enhancing your photos.
I lost my samsung pl120 installation CD. My new system doesn't recognize my camera. How to get the basic software ?
Do you really need the Samsung software?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
Elf name error
hi.you only need to remove your mmc and turn on your camera again and its ok,then format your mmc and insert back to cam.and its ok again
ES90 ZOOM DID NOT OPERAT
If your camera does not operate as you expect, just switch it off, remove the battery for a few moments and replace the battery. Then switch on again.
If you (accidentally) touched the lens barrel, while using the zoom, the camera can act strange, because it tries to protect the hardware for extra damage.
If switching of and on again, does not solve the problem, you should contact a certified Samsung repair centre.
