20 Most Recent
Samsung Digimax 530 Digital Camera Questions & Answers
Is it compatible with windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
Full memory
You are saying it has no SD card in the camera but full memory? I believe the camera has an internal memory storage too... I can't remember how much, it might need to be cleared as well.
How do you get card locked off
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I want digimax 530 drivers
Consider NOT using a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Camera fitted with newly fully
It is a very good possibility that those rechargable batteries have had it.
You probably need new ones.
They are only effective for about two years.
Then you need new ones.
No way around it, they do wear out.
Try NEW rechargeable batteries.
PLEASE COME BACK AND RATE THIS ANSWER
Hello there,........i have a samsung
Once you get the camera working again by the "shuffling technique", don't connect it to the computer again. Instead, purchase an inexpensive card reader and use it to download pictures from now on.
