20 Most Recent
Jensen JXP680 Car Audio Amplifier Questions & Answers
There's a flashing green and
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Protect light
Set your Filter Switch to LPF. Turn the Bass Gain/ level all the way down temporarily. Set your Crossover to below 100HZ. Then Turn on the system with a Bass test sound. Turn up your bass Gain/level until you get distortion. Then turn it back till you just get the distortion out. Then do not warn everyone that you will De-nad them if they touch your settings.
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
