20 Most Recent
Jensen JER-422 Universal Remote Control Questions & Answers
Residential reroof, 3 layers comp.
Probably not required unless an older home or low slope roof, but very easy and not expensive to do when re-roofing. When attics were poorly insulated snow would melt above the attic from heat lost from the house, then refreeze at the eave causing an ice dam. More melting water hits the ice dam then back up under roof shingles and felt paper. It is not required, but your specific conditions could warranty it. If your roofer is recommending it I would do it.
I have a connect-it remote
hello not sure what your remote model number is but i have instructions for the ER-440 and the codes given for the sanyo tv are as follows...
0141, ...0601, ...0981...1111,...1691,...2091,...0151,...0801,...1021,...1291,...1741,...2251
,...2551,...04011,...0821,...1101,...1351,2051
Hope this helps
happy new year.
Sony dvd DAV-TZ130 CHANGE REGION CODE
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the keyword "Region free" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mi control se desconfiguro y no encuentro la
MI CONTROL LG MKJ61841701 SE DESCONFIGURO Y AHORA SOLO TIENE FUNCIONES BASICAS PRENDE Y APAGA CAMBIA CANAL Y SUBE Y BAJA VOLUMEN PERO NO PUEDO ACTIVAR NADA MAS NI MENU NI HORARIO NI ENERGY SAVE NI NINGUNA FUNCION EXTRA. NECESITO AYUDA PARA RECONFIGURARLO. ALGUIEN QUE ME EXPLIQUE QUE HACER. YA HABLE A LG Y ME DICEN QUE COMPRE UNO NUEVO.
Remotes
093,097,091,097 are the codes to check.
If you wish to get more details, check the site linked
below. Pull up older posts there. Setup code list and setup proceedings to
many popular brand remote controls are given. Two digit, three digit, four
digit and five digit setup code list to different models remote controls are
given. If you search the site in Timeslide
option, which can be selected from the drop down list at the top left of the
display window, it will be easy to locate the related post. You can also do a search by type in the
brand name and model number to your device into its search box at the top right
of display window.http://electronicshelponline.blogspot.com/
