20 Most Recent
Panasonic DMR-HS2 DVD Recorder Questions & Answers
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
3/31/2018 1:05:41 AM •
Panasonic...
Answered
on Mar 31, 2018
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
6/27/2011 5:57:59 PM •
Panasonic...
Answered
on Jun 27, 2011
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
4/8/2010 6:05:11 PM •
Panasonic...
Answered
on Apr 08, 2010
RAM Disk won't eject
unfortunately, this unit is on system lock down due to massive main board failure. its kinda like a system protect mode. this can only be repaired by the manufacture or maybe an in house tech with knowledge of the board outline. i don't think this unit has an escape code for retrieving the dvd. hope that helps ya and thanks for using fixya:)
12/27/2009 4:53:00 PM •
Panasonic...
Answered
on Dec 27, 2009
DVD Disc Drive
So farit seems that the laser lense or the laser coil is bad. I found my lense chipped. One site indicated this is because of the use of "bad" DISCs that cause the laser diode to overload because of repeated attempts to read the bad disk. The coil and/or diod get hot and burn. I don't know how my lense got chipped!?
9/4/2008 12:54:55 AM •
Panasonic...
Answered
on Sep 04, 2008
Problem about turning on
Hi, seems that the ribbon cable, which connects HDD & DVD & video-processing card isn't properly fixed to the stripe contactors. If one of both drives isn't connected, ( even on some contacts only) the other doesn't work, resulting in the described fault. The unit won't boot up.
Had this fault atime ago and had to push the ribbons a little harder into the connector and glued it.
Works since then about a year or so.
By the way, I have a 80 Gb replace-HDD, different brand, as the original one failed. NO problems at all, just louder than before, as it isn't the superquiet Maxtor.
If you try to read the unmounted HDD in a PC, the filesystem is changed or disturbed, resulting in the need to FORMAT, when putting it back into the Pana. Done this just by curiosity, all videos gone then. Even with a HDD, that works properly in the Pana.
Alka
5/15/2008 4:02:35 PM •
Panasonic...
Answered
on May 15, 2008
Hard disk failure
It really depends on what is failing on the old drive...accordianman
3/15/2008 8:48:04 PM •
Panasonic...
Answered
on Mar 15, 2008
HS2 doesn't turn on
try holding the power on/off button for about 15 sec to power off completely, then push the DVD button. that may work.
11/20/2007 9:14:24 PM •
Panasonic...
Answered
on Nov 20, 2007
