20 Most Recent Panasonic PT-50LC13 50" Rear Projection HDTV Questions & Answers
5answers
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
6/7/2019 11:04:24 AM • Panasonic... • Answered on Jun 07, 2019
Internal cooling fan
Not aware of any cooling fan in a TV system
11/4/2017 9:26:26 AM • Panasonic... • Answered on Nov 04, 2017
Amber Blinking Light when I turn on the TV Panasonic Large Screen
That appears to be a power supply on its ***** throes. You might want to shop around for a new PS TV Parts Universal TV Stands DLP Chips ShopJimmy Sears Online In Store Shopping Appliances Clothing More
9/20/2017 12:54:28 PM • Panasonic... • Answered on Sep 20, 2017
Indicator light flashing red.
You have a shorted circuit board inside the TV, have it repaired.
7/6/2017 7:23:44 PM • Panasonic... • Answered on Jul 06, 2017
Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
12/11/2016 8:06:27 PM • Panasonic... • Answered on Dec 11, 2016
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
6/3/2016 11:29:50 PM • Panasonic... • Answered on Jun 03, 2016
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
9/15/2015 1:08:05 PM • Panasonic... • Answered on Sep 15, 2015
2answers
Power button flashes Orange every 5 seconds. I have to press the Power button 2,3 times in order for TV to start.
Lamp could be bad or its a power supply problem
2/28/2015 4:45:01 AM • Panasonic... • Answered on Feb 28, 2015
Why does My PT-50LC13 panasonic has a green tint to the entire screen ?
Hello, the optical block or light engine which ever you want to call it has gone bad, it's a very common and expensive repair to which I do not recommend doing. I would put the money into a new set. I'm sorry for the bad news.....tks
9/15/2014 6:35:31 AM • Panasonic... • Answered on Sep 15, 2014
0answers
3answers
Panasonic pt-50lc13 air filter location
It is in the front on the left of the bulb compartment. It is as easy as removing two screws using lots of DAMP Q tips and having some patience. Keep carefully swabbing top and underside filter until clean, then lightly and very carefully vacuum with a home vac do not use a shop vac!
Leave TV unplugged with cover off as long as you can I would say a few hours or overnight and then plug in. If the filter is clean and you still get the error message there are other posts here that explain how to go into service mode and reset.
You do not need to spend hundreds of dollars on a "Panasonic" technician who has "done it before". You can dooooo it!!
7/22/2014 5:19:53 PM • Panasonic... • Answered on Jul 22, 2014
0answers
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
482 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
worth fixing panasonic pt 50lc13 k rear
  • Televison & Video
