20 Most Recent
True GDM-7 Beverage Cooler Questions & Answers
Hi I have two boxes.
Doubt if it is a gas problem. Sounds more like a thermostat issue. Rather surprised that the evap coil is not frosting or freezing up. System may have a defrost cycle or and off cycle defrost long enough to keep it clear. Try to pay attention to the cycling of the compressor to see if it is excessively running long. Thermostat may be available from Restaurant Parts and More. 1-888-814-1110. Talk to Matt or Bryan as they are the most experienced.
Will not stop running
Are you referring to the compressor not shutting off down below or the evaporator fan inside the cooling area not shutting off? Evaporator fan always runs the compressor is controlled by the thermostat you could have a bad thermostat if the compressor never shuts off.
I have a true GDM46
Did you fit a manufacturers original or an after market model?
When the thermostat was replaced was it fitted to exactly where the original thermostat was fitted?
These things are tempremental and must be fitted just so.
Setting are set on 9
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
My drinks keep exploding
You need to turn the thermostat up ....the drinks are frezzing and that explodes them...
heatman101
Beverage cooler not cooling enought
Jeremy, after the line and new filter drier is put in the high pressure side and silver soldered make sure the unit is placed in absolute vacuum for 30 to 60 minutes. It's critical that all air and moisture is remove and the charge applied on low side with out a single air bubble put back in. You may need some on hands help on this solution to get the cooler working properly, Thanks Sea Breeze
True tbb-3g fridge, left hand door sags, creates an air gap at the bottom of the frame where it meets the cooler, door lifts about 1/4 of an inch on the post
If the left-hand door of your True TBB-3G fridge is sagging and creating an air gap at the bottom of the frame where it meets the cooler, here are some steps you can take to fix the issue:
- Check the door hinges: Inspect the hinges on the door and the frame of the fridge. Look for any damage or wear that may be causing the door to sag. If the hinges are damaged, they may need to be replaced.
- Adjust the door hinges: If the hinges are in good condition, try adjusting them to see if this resolves the issue. Use a wrench to loosen the screws that hold the hinges in place, and then adjust the hinges up or down as needed to align the door with the frame. Tighten the screws back in place when you are finished.
- Check the door gasket: If the door gasket is worn or damaged, it may not be sealing properly and causing air gaps. Check the gasket for any damage or signs of wear, and replace it if necessary.
- Check the door closer: The door closer on the left-hand side may be damaged or worn, causing the door to sag. Inspect the closer and look for any signs of damage. If it is damaged, it may need to be replaced.
If none of these steps resolves the issue, you may need to contact a professional repair service to help diagnose and fix the problem.
2/28/2023 5:20:05 AM •
True...
Answered
on Feb 28, 2023
