20 Most Recent
Dremel 10.8V Lithium-Ion Cordless Rotary Tool Kit w/ 40 Accessories - 8000-02 Questions & Answers
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Dremel won't switch off , have had to remove
Either the switch is defective (most likely) or there is a short (less likely).
If it is still under warranty contact the manufacture or the place you purchased it.
If not then you might dismantle it and check the switch to see if it is defective. Use a volt/ohm meter to check for continuity as you toggle the switch. Also check for shorts in the wires or where the wires connect to the switch.
I want to use my USA Dremel Stylus in Europe. I
I presume you want to use a transformer to convert the Europe voltage to USA voltage ( 220 or 240 to 110 )Why not purchase a 240 volt docking station ?Send me the 10 digit number on your Dremel (usually starts with F ) and I can help you.
I bought a dremel 4000 on ebay and it didn't have
Your drill bits side, should have a twisting hand tightening head into which you insert the bits, and have fun. If this is missing, you can either buy it, at dremel stores, or get a nut of the same thread and get the job done.
