20 Most Recent Pro One Multimedia Spanish Questions & Answers
How can i install on 64-bit computer
Just install it and see if it works. 64 bit systems have a subsystem to run the 32 bit programs.
2/6/2014 7:39:51 PM • Pro One... • Answered on Feb 06, 2014
The software disk I have will not work on Windows 7
Depending on the Windows version you have, you may be able to use the software. If you have Windows 7 Professional or Windows 7 Ultimate, you can download the Microsft Virtual PC and XP mode and install them on your computer. In so doing you will be able to run Windows XP on top of Windows 7. While running XP you can install that software and run it from XP. You will be able to communicate with Internet, the printers, everything.Sorry, but you cannot install XP mode on other versions of Windows 7 such as W7 Basic, Home Premium, Just Pro and Ultimate.
8/27/2012 4:52:41 PM • Pro One... • Answered on Aug 27, 2012
My computer is running slow
Try updating the OS to the latest version.
1/7/2024 4:52:59 PM • Pro Computers &... • Answered on Jan 07, 2024
Print Artist Gold. It will not load or start.
I looks like there are known issues https://www.google.com/search?q=Print+Artist+Gold.+It+will+not+load+or+start It says it works with Windows 10. but make sure you have the latest version 25. System Requirements Version 25 Platform Windows XP, Windows Vista 32-bit, Windows Vista 64-bit, Windows 7, Windows 7 64-bit, Windows 7 32-bit, Windows 10, Windows 11
  • Windows XP, Vista, 7, 8, 10, or 11
  • 512 MB RAM
  • 1024 x 768 display or higher
  • Internet connection required
  • Recordable or rewriteable CD drive required to burn CD slideshows
11/22/2023 3:17:58 PM • Pro Computers &... • Answered on Nov 22, 2023
Negative Lab Pro. I need Serial Number please.
Question edited for the proper name of the program. The serial number can be bought here. It is not a free program, but you can get a free trial. Not buying it would be theft and Fixya does not condone theft of intellectual property like software. It is only $99 USD. NEGATIVE LAB PRO v3.0.2 $99.00 USD NEGATIVE LAB PRO V3 brings impossibly good color negative conversions right into your Lightroom workflow. No more messing around with tedious exports and hand-edited curves. Lab-quality tones and colors are just a click away. You'll get:
  • 1-Click Negative Conversions in Lightroom
  • Roll Analysis, for accurate, consistent conversions
  • Intuitive, Non-Destructive Editing Tools
  • Advanced AutoColor and Tonal Control
  • Batch Convert and Edit Multiple Negatives
  • RAW Camera Profiles for Digital Camera Scans
  • Vuescan + Silverfast RAW DNG profiles
  • Lab Scanner Emulations
  • Film Metadata Tools
Requirements:
  • Lightroom Classic (or Lightroom 6.14 standalone)
  • Mac or Windows
BUY NOW - $99 USD
Negative Lab Pro
Negative Lab Pro https://www.negativelabpro.com Recapture the Magic of your Color Negatives. NEGATIVE LAB PRO brings impossibly good color negative conversions right into your Lightroom workflow.
Buy
Advanced AutoColor and Tonal Control; Batch Convert and Edit ...
10/26/2023 1:04:34 AM • Pro Computers &... • Answered on Oct 26, 2023
I have downloaded paintshop pro xi but I cant purchase it cause its out of date i need a serial number can you help me ?
Sorry no. Purchase a new version and pay for it like we have to.
6/20/2023 8:59:23 PM • Pro Computers &... • Answered on Jun 20, 2023
How to change region of CD drive Macbook Pro
To change the region of CD drive on a MacBook Pro, follow the steps below:
  1. Insert a DVD that is from the region you want to change your CD drive to.
  2. Open "DVD Player" application on your MacBook Pro.
  3. Click on "DVD" menu at the top of the screen and select "Region" from the drop-down list.
  4. A pop-up window will appear asking if you want to change the region, click on "Change" button.
  5. If prompted, enter your admin password to allow the change.
  6. Wait for the region to change, it may take a few minutes.
  7. Once the change is complete, you can eject the DVD and insert one from the new region you have set.
Note that you can only change the region of your CD drive a limited number of times, usually up to 5 times. After that, the region will be locked to the last region set, and you won't be able to change it again.
3/1/2023 8:09:22 AM • Pro Computers &... • Answered on Mar 01, 2023
How can i get quick book pro 2011 validation code
Pay for it like everyone else. It is part of the installation package with every new installation.
2/26/2023 7:02:08 PM • Pro Computers &... • Answered on Feb 26, 2023
How to remove and replace wifi card macbook pro A1286
To remove and replace the WiFi card in a MacBook Pro A1286, you will need to follow these steps:
  1. Shut down your MacBook Pro and disconnect the power cord.
  2. Turn the MacBook Pro over and locate the battery. Remove the battery by pressing the battery release latch and pulling the battery out of the computer.
  3. Remove the screws that hold the bottom case in place. There should be 10 screws total, including two hidden screws underneath the rubber feet.
  4. Lift the bottom case off of the MacBook Pro and set it aside.
  5. Locate the WiFi card, which is located near the center of the motherboard. It should be a small rectangular module with an antenna attached to it.
  6. Disconnect the antenna cables from the WiFi card by gently pulling them out of the connectors.
  7. Remove the screws that hold the WiFi card in place. There should be two screws total.
  8. Lift the WiFi card out of the motherboard and set it aside.
  9. Insert the new WiFi card into the motherboard and secure it with the screws.
  10. Reconnect the antenna cables to the new WiFi card.
  11. Replace the bottom case, making sure to align the holes with the screws and secure the case with the screws.
  12. Replace the battery and power on the MacBook Pro to test the new WiFi card.
Note: Be sure to handle the WiFi card carefully, as it is a delicate component and can be damaged easily. If you are not comfortable performing this repair, you may want to consider taking your MacBook Pro to a professional repair service.
12/25/2022 1:52:24 AM • Pro Computers &... • Answered on Dec 25, 2022
Saffire pro 10 not recognize by PC again
If your Saffire Pro 10 is not being recognized by your PC, there are a few things you can try to fix the problem. First, make sure that the Saffire Pro 10 is properly connected to your PC. If the connection is loose, try tightening it. If that doesn't work, try reconnecting the Saffire Pro 10 to a different USB port on your PC. If the Saffire Pro 10 is still not being recognized by your PC, you may need to update the drivers. To do this, go to the Focusrite website and download the latest drivers for the Saffire Pro 10. Once the drivers are installed, restart your PC and try connecting the Saffire Pro 10 again. I hope this helps!
11/22/2022 10:50:00 AM • Pro Computers &... • Answered on Nov 22, 2022
What are master serial numbers of Sony Acid Pro 7?
Question translated into English. There is no 'master serial number', each one is different and assigned to each individual users on payment of a small fee. Sony will help you out. https://www.sony.com/content/sony/en/en_us/SCA/company-news/press-releases/sony-media-software/2008/sonys-new-acid-pro-7-digital-audio-workstation-offers-more-power-and-creative-control-over-professional-music-and-audio-production.html ..
11/20/2022 10:37:20 PM • Pro Computers &... • Answered on Nov 20, 2022
Trying to erase a tattoo on a photo how do i do that
Personally, I would save the photo to Pictures folder, then open it up in FastStone Image Viewer, freeware I would pre-install. With a right click on the file and an Open With FastStone, I would right click again on the photo, choose Edit from the menu, and click on the option invollving cloning. After using it to edit the photo, click on save and the modified photo is saved. I have not checked what formats your original program produces but FastStone is compatible with a lot of formats. Hopefully your program can save in one of such so it can be worked upon as depicted.
9/22/2022 9:45:20 PM • Pro Computers &... • Answered on Sep 22, 2022
Common QuickBooks Pro 2018 Features?
New and Improved Features in QuickBooks Desktop 2018
  • New! Multi-Monitor Support.
  • New! Payroll Liability Payment Reminder.
  • New! Cash/Accrual Toggle on Reports.
  • New! Mobile Inventory Scanning.
  • New! Sales Order Fulfillment Workflow.
9/9/2022 8:15:08 AM • Pro Computers &... • Answered on Sep 09, 2022
How to Install Arlo Pro 3 Floodlight Camera?
There are some very easy and quick steps that will help you to do a proper Arlo Setup . You first need to install the Arlo Pro 3 Floodlight Camera properly. Kindly follow the further steps to Setup Arlo Camera: Open the battery compartment by squeezing the hook and pulling back tenderly. Embed the battery as displayed and close the battery entryway. Carry the camera inside one to three feet (30 to 100 centimeters) of the base station. Sync the camera to the base station: In the event that you are utilizing an Arlo base station, press the Sync button on the base station for around two seconds and afterward discharge the button. Note: If you press the Sync button on the Arlo base station for a really long time, the LED under the USB image flickers golden for 10 minutes. While the USB LED is flickering golden, the sync interaction is obstructed. Assuming you are utilizing an Arlo Pro 3 base station, press the button on the highest point of the base station for around two seconds and afterward discharge the button. Sit tight for the sync status LED to squint green. Press the Sync button on top of the camera for around two seconds and afterward discharge the button. A blue LED on the camera flickers quickly to affirm sync. In the event that the LED on the camera squints golden, the sync isn't effective. You should rehash the sync interaction. Check the camera LED on the base station. In the event that the camera LED on the base station turns strong green, the sync interaction is finished. Rehash these means for every camera. Note: If you don't finish the sync cycle within 60 seconds, press the button on the highest point of the base station and attempt once more. Enter a proper key phrase to not face Arlo Login Issue . Hopefully, you will be familiar with how to install Arlo Pro 3 Floodlight Camera. Proper installation helps to solve Arlo Camera Offline issues also.
1/27/2022 5:13:05 AM • Pro Computers &... • Answered on Jan 27, 2022
Quattro pro 2020 saying "invalid cell or block address {let} in certain cell. this worked in quattro pro 8. how do i fix it?
animal mineral vegetable.? NO PC told no OS told wow. ahhhh an old video card>?nah its a office app. super set of old lotus 1,2,3. 1988 to 2020 i have not touched it since 1991. wow. well reload the app. here is what ID do. always first. I test all HDD involved first. the OS HDD or SSD and all other driver Quattro uses, other HDD?> in my case MS office is loaded to drive F: a m2. extra drive. test all those first, and if passing reload that app. if the unstated PC runs ok load this fee and 100% safe aff https://www.passmark.com/products/diskcheckup/ all drives must show PASS. or call ("IT") and get help? no hdd lasts forever, most fails 5 years old no os runs on bad hDD no quattro runs on any bad HDD so that is first. best if in a business we run it on RAID 6 server all that and never fails at the server can have 2 drives fail and just keeps working with zero corruption/. on any PC , this fails so easy , hdd dies, and so does all. it can fail in progressive way like cancer. or just go dead.
1/18/2022 3:03:27 PM • Pro Computers &... • Answered on Jan 18, 2022
Quick heal error 2 while installing quickheal pro antivirus
Ask them. It is their shonky software! Also unknown in the western world. What is wrong with Avira or Kaspersky?
Downloading update failed. Error ID: 1002 Please wait for ...
https://techsupport.quickheal.com > Downloading-upda... Feb 18, 2020 - Symptoms: You may come across Update error 1002 whenever we try to update Quick Heal Antivirus with the following symptoms:.
12/22/2021 3:57:13 AM • Pro Computers &... • Answered on Dec 22, 2021
Pro form cross trainer error code
10/30/2021 11:29:09 PM • Pro Computers &... • Answered on Oct 30, 2021
Pro One Multimedia Spanish Logo
3 questions posted
Top Pro Computers & Internet Experts
k24674
deton8 von Splosion
Robbie Goodwin
Are you a Pro Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Pro Computers & Internet
Most Popular Question
software disk will not work windows 7
  • Computers & Internet
