20 Most Recent Sony FD Trinitron WEGA KV-36HS510 36" TV Questions & Answers
Hi, I'm using a Sony
If your TV connected through stabiliser, disconnect stabiliser , connect TV directly to plug socket. and check up.If TV works your stabiliser is defective.
12/18/2017 5:57:30 AM • Sony FD... • Answered on Dec 18, 2017
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels. 1 Press POWER to turn on the TV. 2 Press TV FUNCTION on the remote control. 3 To continue running Auto Setup, press CH+. To exit Auto Setup, press CH-. Auto Setup automatically creates a list of receivable channels. When finished, the lowest numbered channel is displayed. To reset the TV to factory settings 1 Press POWER to turn on the TV. 2 Hold down RESET on the remote control. 3 Press TV POWER on the TV. (The TV will turn itself off, then back on.) 4 Release RESET.
5/17/2016 10:42:44 PM • Sony FD... • Answered on May 17, 2016
How can I unlock channel?
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
4/15/2016 6:46:35 AM • Sony FD... • Answered on Apr 15, 2016
Where can you buy the A1300319A Board. I cant find one.
You are correct. What is the issue with the one that you have?
1/29/2016 11:21:09 PM • Sony FD... • Answered on Jan 29, 2016
Why wont my Sony trinitron tv turn on but stand by light flashes?
That Flashing Standby Light Indicates A Defect In Your Low Voltage Or High Voltage Power Supplies...
6/30/2014 6:49:41 PM • Sony FD... • Answered on Jun 30, 2014
0answers
No picture only sound
that problem smetimes in the heater of crt check filament small amount of light if not maybe risistor of the heater is open or loose look for it
1/22/2014 2:29:05 AM • Sony FD... • Answered on Jan 22, 2014
No picture only sounds
look for loose connection in high voltage or horizontal section ,resolder jungle ic
1/22/2014 2:03:09 AM • Sony FD... • Answered on Jan 22, 2014
Sony manuals
http://remotes.com/ You can with a good universal remote control that have the feature in it. But above the webpage to get your own original remote control for your tv. Good luck
12/18/2013 2:44:36 AM • Sony FD... • Answered on Dec 18, 2013
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
9/24/2013 4:50:36 PM • Sony FD... • Answered on Sep 24, 2013
Sony wont turn on but will blink in stanby
How many times do this standby light blinks? Count it. These are blinking codes, and are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. To get more information about blinking codes, check this site. It has details to many brand TVs' blinking codes, including Sony. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/9/2013 3:09:55 PM • Sony FD... • Answered on Sep 09, 2013
TV TURNS OFF ON ITS OWN
11 blinks won't occur to this TV. It might be 10 blinks. If so Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.If you want more details about the blinking codes to Sony TVs, check this site.
1/18/2013 5:04:56 PM • Sony FD... • Answered on Jan 18, 2013
3answers
Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
11/5/2012 12:05:06 AM • Sony FD... • Answered on Nov 05, 2012
My sony trinitron tv sometimes turns on then right back off or turns on volume only then few days later it works fine. whats up?
Check for any loose solder connections in the main power regulator section of this TV. It will be very difficult to detect loose solder terminals, as they will be microscopically small to ***** eye. It is best to re-solder all the suspected solder terminals by applying a little more fresh solder to each solder terminals.
10/27/2012 4:08:20 PM • Sony FD... • Answered on Oct 27, 2012
My kv36hs510 2003 falt screen tv wont turn on but you can hear it trying to turn on, what can i do?
This set is very heavy and if fails to come on the power light should blink a specific number of blinks repeated over and over.There are almost no customer repairs possible here as every part is special and Sony only---even as much as these sets cost new most when fail are being retired/recycled and replaced.Typical repair cost in most cases will exceed 200 dollars or more.
10/22/2012 4:10:01 PM • Sony FD... • Answered on Oct 22, 2012
Sony wega KV-36FS13 standby light blinking 5
Ur power ic inverter board is dead.
U need a new one.
10/14/2012 4:37:34 PM • Sony FD... • Answered on Oct 14, 2012
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
156 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
tv turns off its own
  • Televison & Video
