20 Most Recent
Sony FD Trinitron WEGA KV-34HS420 34" TV Questions & Answers
The standby light flashes and the tv will not come
check the power supply, its not giving out the required voltage output. if you cant repair a tv plse take it to a workshop, ask a technician to make sure that he checks the following components.
power diodes and transistor, fusable resistors around the power supply, and zener diodes.
he should make sure that an ht of 95-110 volts appears on the line transformer. later a transformer will produce various voltages to trigger other voltages to open up your tv. thanks
4/7/2017 6:14:06 AM •
Sony FD...
Answered
on Apr 07, 2017
I have a Sony KV-40XBR800 TV, what board is the component or technology that controls 16:9 and 4:3 aspect ratio located on the motherboard/chassis, A, B, CX, D, HA, HB, HC, HM, M, U, UD or W.
I would think that the board with the horizontal output circuits and flyback transformer is the area of concern.
3/31/2017 9:10:21 PM •
Sony FD...
Answered
on Mar 31, 2017
My new (used) Sony Trintiron
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
1/25/2015 7:36:11 PM •
Sony FD...
Answered
on Jan 25, 2015
My Sony TruSurround by SRS has no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
7/29/2014 4:19:55 AM •
Sony FD...
Answered
on Jul 29, 2014
Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
6/12/2014 10:01:39 AM •
Sony FD...
Answered
on Jun 12, 2014
I can't figure out how
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
3/20/2014 11:58:53 PM •
Sony FD...
Answered
on Mar 20, 2014
Sony kvhp21m83
Download the repair manual to this set. It has all details. Repair manuals are in PDF, and cannot include here by this window. If you wish to get some details, check the site linked here.
http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
1/5/2014 9:32:39 AM •
Sony FD...
Answered
on Jan 05, 2014
