20 Most Recent
Sony PFM-42V1 42 in. HD-Ready Plasma Television Questions & Answers
GREEN ON LITE COMES ON, BUT EVERY FEW SECONDS THE
Sounds like the power supply. The supply checks for all the various voltages to be there - if they are not it shuts down. It then tries again. So if you are hearing the click in/out of the PS relay that's where the trouble is. Before buying another PS at least disconnect the Ysus and Zsus suppy lines to make sure they are not pulling it down. If they aren't - it's the power supply. It's a complex board (PKG-4014) and if you ever get a diagram I love a copy - they are never in the manuals. Mine was one of the 3641 regulator chips. Hope this is of some help.
I dont know what chords
Hello bobbylanetra,
if your tv does not have the composite connection (the red, white and yellow), I am going to assume that you have a coax in though. So what you should do is get an RF modulator. Connect your dvd player OUT to the RF modulator IN with the composite cable, then use a coax cable and connect the RF modulator OUT to the coax IN of the tv. That should solve your issue. I hope this helps or if not give me a feedback, good luck.
- Joe
Vertical black lines on screen
Unfortunately it sounds like the video processor or a capacitor inside the TV has started malfunctioning, causing the vertical lines. I recommend contacting where you purchased the TV from and ask for help regarding a repair or replacement if it's still in warranty.
Hope I helped,
MichaelPrest
Where is the coaxial connection
Look at the back of the tv. Bend down and then look up and you will see the coaxil connection and possibly other rca connectors as well.
Possible frame output fault on Sony PFM 42 V1 plasma display
This sounds like a fault with the sustain boards. Can you provide me an image of the tv when the problem appears? Also I need a bit more info regarding the problem
1)Since these compressed frames appear in the middle of the tv, do they appear on top of the menus as well?
2)Do they lose color(monochrome) or do these lines retain the color?
3)Also do the lies stay all the while or appear/disappear a while after its turned on for a while?
Sai.
My tv has a aprx 3
hello,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
in
most cases this will be a bad buffer module. this board is called other names
but they all do the same work.but a cost will range around $500.00. in some cases it is the display itself
and a cost would be more than you paid for the unit. but this is not common.
good luck...
Can someone help with the name/product code number
1) "Composite Video" cable yellow
and two red and white audio cable should 100% work
if you have a Video out/in jack on tv and reciver
100% it will be there.
and it will work
just you need to ask for "Video in" (also called composite video cable) cable with both side yellow jack
regards
Turns on/off but no on
Could you please tell me the number of Blinks you could See?
For Example - 6 Blinks then pause and then 6 blinks?
What is the Color of LED? How old the Unit is?
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
