20 Most Recent
U-Line 2075RF Compact Refrigerator Questions & Answers
My U-Line frig, model 2075RF
Yes if thier is a refrigerant leak thats about what it cost to repair it..quite honestly it sounds to me as if you had a good service tech out since most will only recharge the refrigerant and never address the reason it was low (a leak) in the first place
GENE
Where is the condenser fan
The condenser on your u-line compact refrigerator it an in built i.e it is your compact refrigerator make use of internal condenser some time at the BACK or at the LEFT HARD side INTERNALLY.
Hope this help?
Thank you and thanks for using fixya.
Freezer door will not stay closed
You will need to replace the freezer door hinge assembly. Also make sure that nothng is blocking it from closing. And check the door for any warping
The alert notification is from a u-line refrigerator and beeps even when door fully closed
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
6/1/2018 4:50:59 AM •
U-Line...
Answered
on Jun 01, 2018
