20 Most Recent
Sony SA-WX700 Subwoofer Questions & Answers
My sony SA-wx700 sub woofer does not have a sound
Check out this link to a thread. I bought a Sony SAWX-700. The light came on when plugged in. The guy said he didn't have a way to test it, but assured be the light was on and that it worked. I got home and it didn't. Did a search and found these posts. I followed them, ordred the parts and fixed it for like $10.00.Hope this helps! I also did a Youtube search on how to solder and desolder and wasn't that hard.
http://www.avsforum.com/avs-vb/showthread.php?t=944798
Have a sony sa-wx700 home
THI NOISE IS CAUSED BY A FAILING TRANSISTOR IN THE AMPLIFIER, AS THE TRANSISTOR FUNCTION COMES AND GOES IT MAKES A STATIC POP, U WILL NEED TO HAVE IT REPAIRED OR DEPENDING ON THE REPAIR COST REPLACED.
Power turns(light) but no sound. Fuses all good??
apparently there is are some components on the main board that need replacing:
This is usually what needs to be replaced on these subs.
Replace
R830
R831-4.7 ohm 5% 1/4w fusible
C860 - 082 mf 5% 50v
Direct from Sony:
hxxp://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
c860 is Part # 113616400 $2.14
r830 is Part # 121284900 $2.14
Sony SAWX700, powers on fine, subs are not blown but no sound
The problem may be with the preamp power supply section. Easy fix in most cases. This is a great sub, they don't build them this well anymore. From Sony, I was quoted around $200 plus the bad board in exchange. The part to fix it costs $1.00, labour an hour or less. Get it fixed. The other brands have gone cheap with components and build quality. Let me know if you want more info.
Humm noise coming from 10" 100watt sub only plugged into wall...
If you're using it first time, check the sub cable u're using, low-quality rca cables can easily pretend to act as an antenna and pick up parasite and hum from electric lines or from other devices, also another factor is too-long cable. If u're using a cable longer than 5m, it should be really hi-quality and well screened. Or the hum is inevitable. I hope this helps.
