20 Most Recent Acme 5001 Supreme Juicerator Juice Extractor Questions & Answers
MAKES A LOUD NOISE
disassemble clean and assemble paying attention to condition noise from bearings going out/screeching ??? noise from unbalanced load/ lots of vibration?? noise from scraping/grinding/metal on plastic ?? noise from scraping/grinding/plastic on plastic ?? there any burning smell also ?? is any part getting warm ( turn upside down to check ) ( hold or place on thick layer of kitchen towels be aware if it is old ~ 20 yrs give or take 20 yrs getting a new juicer will be less hassle than trying to repair
4/2/2019 3:18:51 PM • Acme 5001... • Answered on Apr 02, 2019
Rubber rubber feet are worn out. Can I buy new feet.
yes new rubber feet are available easy to install
4/2/2019 3:06:04 PM • Acme 5001... • Answered on Apr 02, 2019
5answers
Lid wont come off
same problem; looking for solution
6/3/2013 9:57:06 PM • Acme 5001... • Answered on Jun 03, 2013
Acme Supreme Juicerator 6001 Model # 11JE21
REMOVE THE COVER BY ROTATING AND
THE CLUTCH NUT HOLDING DOWN THE
CUTTING BLADE. EVERYTHING LIFTS OFF.
CLEAN ALL DISCOLORED PARTS BY FIRST
BOILING IN A SOLUTION OF OXI CLEAN AND
WATER, THEN SCRUB WITH A SAFE
ABRASIVE SPONGE. SHE WILL SHINE UP
NICE.
5/8/2013 2:12:58 AM • Acme 5001... • Answered on May 08, 2013
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
1/6/2013 11:43:48 PM • Acme 5001... • Answered on Jan 06, 2013
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link: http://www.everythingkitchens.com/PDFfiles/6001.pdfItems to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
7/24/2012 4:09:19 AM • Acme 5001... • Answered on Jul 24, 2012
3answers
Why does my supreme juicerator shake and make
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
4/25/2012 2:40:14 AM • Acme 5001... • Answered on Apr 25, 2012
2answers
Acme Juicer
WARING HANDLES THEM AT 800 492 7464.
HOW OLD IS IT? BEARINGS COULD BE GONE.
THEY ARE REPLACEABLE.
2/16/2012 8:24:39 PM • Acme 5001... • Answered on Feb 16, 2012
tip
How to keep your juicer from jumping all over the place.
I have found celery is the big problem, instead of putting in the whole stalk cutit into small 2 inch pieces, when I do this I have no problem, otherwise myjuicer is jumping all over the counter. I believe it is the long strings in thecelery that somehow gets caught around the parts. At least it has madejuicing a pleasure for me. Hope it works for you. If this has helped you please let me know, [email protected]
2answers
I need a manual for acme supreme juicerator.
I found that one here.
I searched this for you, please leave a good rating!
12/28/2011 7:29:53 AM • Acme 5001... • Answered on Dec 28, 2011
I am not able to
Try the reset button on the bottom of the juicer.
4/26/2011 6:05:37 AM • Acme 5001... • Answered on Apr 26, 2011
Want to see all parts, not sure my juicer has all
Juice bowl goes on first, then basket, blade, clutch nut followed by cover which
rotates shut, and of course the food plunger.
4/26/2011 6:03:25 AM • Acme 5001... • Answered on Apr 26, 2011
Motor runs and is seem like it has a clutch that
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
4/26/2011 6:00:29 AM • Acme 5001... • Answered on Apr 26, 2011
I have an acme juicerator
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
4/26/2011 5:52:08 AM • Acme 5001... • Answered on Apr 26, 2011
I am juicing oranges with ths acme juicerator and
Not really designed for juicing oranges. There is a citrus attachment but it costs too much,
better off buying a $20 citrus juicer.
4/20/2011 4:11:45 AM • Acme 5001... • Answered on Apr 20, 2011
Filters
Do without them. They lessen the yield and cleaning
the juicer is not that difficult.
1/30/2011 5:58:32 AM • Acme 5001... • Answered on Jan 30, 2011
Dull Blade
Call Waring at 1 800 492-7464.
1/30/2011 5:56:53 AM • Acme 5001... • Answered on Jan 30, 2011
Acme 5001 Supreme Juicerator Juice Extractor Logo
90 questions posted
Popular Products
Top Acme Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Acme Juicer Expert? Answer questions, earn points and help others
View Most Popular
Acme Juicers
  • Acme Juicers
Most Popular Question
acme juicerator
  • Juicers
