20 Most Recent
Sylvania 6719DC 19 in. TV/VCR/DVD Combo Questions & Answers
My televison talks in english one program then the
You may want to check that you are not listening to the secondary audio program (SAP). I am not sure how to check this on your TV, but I would start by poking around the menu of the TV in the audio section if there is one.
Codes for criag dvd player
287,281,284,286,222,000 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to
many popular brand remote controls are given. Two digit, three digit, four
digit and five digit setup code list to different models remote controls are
given. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name and model number to your device into its search box at the top right
of display window.
What is sap
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
How to eject dvd
Someone needs to look inside to see if something got inside and is stopping the mechanism from working---I have even seen a few which someone had managed to get 2 discs in at same time.If the mechanism is damaged it may not be worth repair as the DVD portion (if even available) costs too much.
Sylvania tv/vcr/dvd keeps going from channel 3 to AUX
Hi my name is Mike Houston of DISH Network, with the TVswitching between channel 3 and AUX there are some things to check to resolvethe issue. You will want to make sure all connections are hand tight from thereceiver to the TV and to the wall. After all connections are hand tight checkto see if the channels are still going back and fourth. If it still persiststry changing the remote address, I will send a link that better explains thissetup; http://www.dishnetwork.com/SupportSection/remote-setup
How do you run channel
HI,
To auto preset channels do the following procedure.
1. Press the
SETUP button on the remote.
2. Using
UP/DOWN arrow Select
CHANNEL SET UP and press the
RIGHT arrow to enter to channel preset
3. Using
UP/DOWN arrow select
AUTO PRESET and press the
RIGHT arrow to start the auto scan.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
The remote control stopped working.
press button and face it to any mobile camera like nokia 6680 or htc touch.if light come out then its not your remote problem its you tv infrared sensor problem.
